Author Topic: Got Gas?  (Read 2300 times)
Offline Prospect
Got Gas?
« on: July 27, 2012, 01:52:42 PM »
What kind of fuel are you guys using in these old cb's?  Apparently we have different additives here in Canada than our friends down south.  I've been told by a fairly unreliable source that shell has the best fuel for old harleys and cb's but I've always ran regular in them.
« Last Edit: July 27, 2012, 01:54:19 PM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Re: Got Gas?
« Reply #1 on: July 27, 2012, 02:20:57 PM »
Generally, the pre-1972 SOHC4 bikes required old-style premium gas. Today the 'mid-grade' fuels (in the US) have approximately the same burn rate as those old premiums, because of the added ethanol.
Starting in 1973, the SOHC4 engines were all retuned for less octane. They ran well on old-style regular gas then. Today, it is best to test between the regular and mid-grade on a given bike to see which one causes smoother throttle response: if there is pronounced throttle lag in the low midrange area with a big throttle pull, try a higher grade of fuel to see if it helps.
Offline CrankyOldGuy
  • Wish I was a
Re: Got Gas?
« Reply #2 on: August 15, 2012, 10:51:20 AM »
Prospect,
Here in NB we have regular with 10% ethanol, midgrade with 5% ethanol, and premium with 0% ethanol.  At present I plan to try the premium grade with my 750K1.  I always used premium back in the day ... 35 years ago  ::)
Harry O.
750 K1 Original Owner
