Author Topic: 1975 CB550 brat build... (new pics, new bars, new stuff)  (Read 41083 times)
Offline xnewmanx
« on: August 14, 2012, 07:20:32 PM »
First off, I'll say that I hate using terms like "brat" and "cafe" because that makes me feel like I am trying to fit a mold.
A little back story on the bike:
I got the bike about 8 years ago at a garage sale for, I kid you not, 10 dollars.  It was 100% stock, no rust on it at all.  Actually just jumped it and drove it home. But then once I got it home I did a couple burnouts with it and popped the tire so I just left it outside for a year or two and it got sort of #$%*ted up from the rain and snow.  A year or so later I decided I wanted to ride it so I went to retrieve it and someone had backed into it and bent the bars and broken the side covers.  I threw some clipons on it and took the front pegs off of it and just flipped the shifter and used the rear.  I drove it like that for a few years until this summer the mod bug bit me and I really went to town.
Here's what it looked like when I got it (these pics are SUPER lame but they're about 8 years old, so cut me some slack)
So after this summer I really started cutting it up.  I love cutting stuff up.
Everything I did was done very quickly in order to minimize downtime.  I don't think the bike was off the road for more than 4 days at a time at most.
the first thing I did was slap on DOT dual sport tires.  (Did this in my garage with tire levers)
Then I cut the back off and moved the shock mounting points forward an inch and a hlaf:
And welded on part of some BMX handlebars:
Made a cardboard template for a seat pan:
Cut it out of 16ga and bent it up in a vice:
Glued together several layers of a weight lifting mat:
Started to carve it with air tools:
Finished:
Made a template out of cardboard for a cover:
Bought some marine vinyl and sewed some diamond pattern in it, then sewed together the whole seat:
Seat installed.  It came out OK.  Enough for the scope of the project... wasn't looking for perfection:
No pics, but I also welded brackets to mount the swingarm to the fender, built a taillight bracket, beat the tank in with a hammer to make it more comfortable, installed lowering springs out back, lowered the fork in the trees.
This is how it sat after the initial round of tweaking:
« Last Edit: August 22, 2012, 12:57:46 PM by xnewmanx »
Offline xnewmanx
Re: 1975 CB550 brat build...
« Reply #1 on: August 14, 2012, 07:22:37 PM »
Next came:
Off an 07 GSXR.  Paid about 250 or 300 for the whole setup.  Built everything required to install them.
Sticking with single disc.
Driving around withno front brake...  :)
Offline xnewmanx
« Reply #2 on: August 14, 2012, 07:23:58 PM »
Machined a front brake adapter and got the brakes on:
Then I decided I wasn't digging the ride/look with rearsets and wanted to change to high mid controls.  So I built some #$%* from scratch (even the pegs). IDGAF about the welds.  :)  Also threw on a BMX kicker pedal.
This is the riding position before:
I wanted something like this.  More aggressive.
So here's how I did it:
^^^ yeah, that's a 3/8" socket for the shifter peg.
And here's how she sits now:
Then I ordered 400 dollars worth of stainless u bends for a custom exhaust  :)
Offline xnewmanx
« Reply #3 on: August 14, 2012, 07:27:15 PM »
Next it was time to build the exhaust.  Had some fun with it.  Just kinda started with the front and worked back:
All 304SS mandrel tube.  At this point it was just tacked
And here it is all tig welded up.  I also made some "lollipops" which are washers welded to bolts to increase backpressure in the exhaust. Took off the airbox (in anticipation of the velocity stacks I have on order) Rejetted the carbs from 100 to 110 (38 to 40 for pilot).  Runs awesome.  Sounds awesome.
Offline xnewmanx
« Reply #4 on: August 14, 2012, 07:27:49 PM »
And here are some pics of the exhaust installed. Made some filler plates because I felt the rear was a little vacant... 12GA Aluminum.
Then I found this super old tractor taillight at work.  Gonna replace the lame ebay unit...
Offline xnewmanx
« Reply #5 on: August 14, 2012, 07:28:22 PM »
Here's the old tractor tail light mounted up:
Offline xnewmanx
« Reply #6 on: August 14, 2012, 07:29:00 PM »
Nex I made a suicide clutch and jockey shift.  I have a plan.  This isn't bad to ride either...  :)
Offline Boostisfordinnr
« Reply #7 on: August 14, 2012, 07:29:33 PM »
I dig the originality of this build. I also have the same thoughts when it comes to "cafe" and "brat", also "bob" and "chop". I do things for me and me alone, I feel you have done the same thing and I commend you for that.
How do those tires ride?
Offline xnewmanx
« Reply #8 on: August 14, 2012, 07:30:10 PM »
Bought a rear master cylinder from an R6 and attached it to the frame.  Ran a hydraulic line up to the front brake.  Took the brake lever off. Cut the bars down.  I think I am going to make some really low rise attack bars for it, but the clipons will do til then.  I also replaced the shifter seal that had been leaking oil ever since I bought it.
I also put some vintage amp "jewels" from a fender guitar amplifier in the back fender.  Also installed steel dragon "old school" velocity stacks.
A few pics of the whole shebang...
This is how she sits currently!
I have some more plans in the works...
Offline BillGodRules
« Reply #9 on: August 16, 2012, 06:26:22 AM »
Nice looking bike XNEWMANX.  $10?  Nice score. I have a 500 the same color.  Just curious what are you doing with the stock parts you are taking off?  I may be interested in the exhaust if the price is right. What sort of shape is it in?
Offline xnewmanx
« Reply #10 on: August 16, 2012, 12:11:34 PM »
Most of the stuff I threw away, but I still have the exhaust.  There are some pinholes in the bottom of it, though.
Offline Mcwilliams570
« Reply #11 on: August 16, 2012, 01:28:13 PM »
I really like the look of your bike very nicely done hats of to you made me really look at it and get some ideas..
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline cb550choppa
  • ride it like you hate it
« Reply #12 on: August 16, 2012, 03:52:10 PM »
that thing is pure awesome
chop what ya got
« Reply #13 on: August 16, 2012, 04:00:44 PM »
Quick question how is the rear fender mounted..
Matt
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline xnewmanx
« Reply #14 on: August 16, 2012, 04:45:36 PM »
Matt
on struts welded to the swingarm.
Offline xnewmanx
« Reply #15 on: August 16, 2012, 05:11:52 PM »
So today I shortened the forks internally which allowed me to put them in a normal position in the triple clamp.  I also removed the steering damper.  The result is a super clean front end.  Still unsure if I want to do anything as far as building bars or if I should stick with the clipons.
Offline Finksies
« Reply #16 on: August 16, 2012, 05:16:37 PM »
cool bike, do u have a link to what u used for your front brake lines? Never seen that before.
Offline xnewmanx
« Reply #17 on: August 16, 2012, 05:22:47 PM »
what do you mean?  It's just a 25 dollar piece of braided hose from summitracing???
Offline xnewmanx
« Reply #18 on: August 16, 2012, 08:51:07 PM »
OK, so in these pics you can see that the fork tubes are pretty close to the top of the triple tree.  I tried putting them flush but it didn't look right.  I also removed the steering damper.  I may attach it underneath the triple at a later date.
Here is a closeup of the jewels in the fender.  They serve no purpose.  Strictly aesthetic.
And lastly I removed the nuts on the shift lever and replaced it with a pretty rare Japanese one from a boutique auto company called cruise.  There are probably hardly any like it in the states.  It was a special order item direct from japan that I had intended to use on my BMW but never did...
Offline greenjeans
  • 1972 CB750K2
« Reply #19 on: August 20, 2012, 05:18:07 AM »
Have to say....when I saw the first photo in the thread, I almost didn't look any further  ;)
But, I am glad that I did.   Love it.  Really dig your style on that one.    Very unique industrial style.
Something about those knobbies...
Offline jaguar
« Reply #20 on: August 21, 2012, 04:50:55 PM »
Where in NY are you?
Offline Dannodarko
« Reply #21 on: August 21, 2012, 05:07:01 PM »
Awesome build
Offline kerryb
  • Not a very
« Reply #22 on: August 21, 2012, 09:16:32 PM »
Very creative...I'm looking forward to the attack bars.
Offline corey607
« Reply #23 on: August 22, 2012, 07:48:24 AM »
Cool ideas. how did you run the clutch cable?
Offline Blitzburgh207
« Reply #24 on: August 22, 2012, 08:29:36 AM »
I like the way you see things  8) Cool build - very original.
1978 CB750 K8
