Author Topic: 1977 CB400f Carb woes  (Read 2594 times)
Offline JPS888
« on: September 09, 2012, 05:38:28 AM »
Hi, new to this forum, Please HELP , have running issues , terrible flat spot under slight load & will not rev out, leaks fuel after running through overflows even with petcock switched off .
Have now changed float needle valves & cleaned fuel bowls & refitted with service kits from David silver.
Still slight hesitation & flat spot under slight load but not all of the time ! although running 80% better than before.
Any ideas ? Float level height ?
Thanks . :o
« Last Edit: September 10, 2012, 11:30:21 PM by JPS888 »
Offline JPS888
Re: 1977 CB400f Carb woes
« Reply #1 on: September 10, 2012, 11:33:57 PM »
Getting desperate, anyone out there with any ideas ? please.......
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: September 11, 2012, 01:13:23 AM »
Have the carbs been completely apart to clean the midrange/emulsifier tubes? That item can be problematic on the 400 four, especially if the bike had been sitting for any period of time...Larry
Offline JPS888
« Reply #3 on: September 11, 2012, 05:39:25 AM »
Thanks Larry will try that one next then !!!!! ::)
« Reply #4 on: September 11, 2012, 06:53:40 AM »
^^^this!
Offline Cundalini
  • Honda CB400 Four owner since 1986
« Reply #5 on: September 11, 2012, 11:39:41 AM »
If fuel leaks out the overflow pipes when running or not ,the float bowls are the wrong height OR a valve isn`t seating properly.In that there is something trapped like a bit of grit stopping the valve closing.
Cundalini wants his hand back.
Offline fmctm1sw
« Reply #6 on: September 11, 2012, 11:48:13 AM »
Make sure your standpipes in the float bowls aren't cracked....
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline JPS888
« Reply #7 on: September 11, 2012, 10:56:17 PM »
Thanks guys, will check both these , bike wouldn't start for a minute or two last night ! seemed to have a fuel starvation problem , so does this lean towards float height being wrong....~? will have to have carbs out again at some point...A :Dlthough they have stopped leaking through the overflows since replacing the needle valves.
Offline camelman
  • Man... Myth... Legend
« Reply #8 on: September 11, 2012, 11:54:20 PM »
It leans towards your carbs being dirty.  Check the FAQ for a description of how to clean your carbs.  You'll have to go through them in detail to make sure everything is good.  Carbs and a bad battery at the typical culprits on these bikes.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
