Author Topic: Anyone got any tricks to get this last engine bolt out  (Read 1100 times)
Offline Mcwilliams570
« on: September 16, 2012, 07:47:07 AM »
I have a old cb500 engine that has been sitting in the frame for awhile now and want to remove it so I can store the frame and move stuff around a bit easier.
This last bolt is being a pain to get out seems like it is bent so its not coming out easy. Anyone have a trick to help me out here.
Thanks Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Re: Anyone got any tricks to get this last engine bolt out
« Reply #1 on: September 16, 2012, 07:58:16 AM »
A drift punch and a BFH comes to mind! Have you tried jacking the motor up slightly to relieve any pressure?
Offline devillox
  • like a parasite, like a leech
« Reply #2 on: September 16, 2012, 08:02:45 AM »
Same problem with my 750... What Stev-o said. A little lift was all it needed.
« Reply #3 on: September 16, 2012, 08:28:46 AM »
 If you mean the long bolt, it will be loose as soon as it clears the frame portion. If willing to replace you can cut off the head or  drill a hole in a bar to put over the threaded part to straighten(it will hurt the threads) If you take the time to tap a correct hole in a bar, you may get it quite straight..
« Reply #4 on: September 16, 2012, 10:12:22 AM »
I spun it with an impact while pushing with a drift pin. Spray some lube where ever it has a chance to soak in. Some of them get quite corroded inside.
« Reply #5 on: September 16, 2012, 10:16:54 AM »
 Dont spin it, it will try to enlarge the hole, they are oversized already...
