Author Topic: ignition switch part#  (Read 1317 times)
wilson11
« on: July 01, 2006, 05:53:09 PM »
Hello everybody. It seems that the key switch for my american model cb400f has gone kaput and needs replacing. Has anybody got the proper part # for this. I have a parts manual for this but there are a lot of them listed and I would like some clarification on this as the price for a oem one is expensive. Has anybody tried an aftermarket one with good results? Does any other Honda switches from other models work or are these model specific? The bike is a 75 model.
        Thanks
Offline puppytrax
Re: ignition switch part#
« Reply #1 on: July 01, 2006, 06:51:26 PM »
...as the price for a oem one is expensive...
I should say so...
LOCK SET
35010-377-007 (replaces 35010-377-000)    001    $151.70
http://partsfinder.ridenow.com/fiche_section_detail.asp?category=Motorcycles&make=Honda&year=1975&fveh=2911
"Combination Switch"
Hmmmm...don't you also have helmet/seat lock, and a fork lock too??? Might as well get them all keyed the same...   ;)
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline volz1fsu
« Reply #2 on: July 01, 2006, 08:27:08 PM »
I got a new aftermarket switch for just a little over $10.  It works great, no problems so far over the course of a few years.
« Reply #3 on: July 02, 2006, 04:31:56 AM »
same ignition switch as cbx, 550 (77/78) i think. Also you can get just the plastic electrical bit seperate but dealers dont like trying to find it!
Online Bodi
« Reply #4 on: July 02, 2006, 09:07:45 AM »
I got one of the Chinese replacement ones (Emgo) and it lasted a bit longer than it took to put it in, not by much.
I fixed the original one and put it back in. The little door for the key doesn't work but otherwise it's great.
I think the key set from DSS or Honda would be worth the $$$. You get all 3 locks and a set of keys, the switch should last another 30 years. (vs 30 minutes for Emgo)
« Last Edit: July 02, 2006, 09:09:25 AM by Bodi »
