Author Topic: cam chain  (Read 1180 times)
waterman56
cam chain
« on: July 01, 2006, 06:14:16 PM »
Hi
I have a 77 750 ss f runs great with 15,500 miles think it is a stupid question but how do you loosen cam chain lock nut what size wrench etc
Thanks
Offline Bob Wessner
  • "Carbs Suck!"
Re: cam chain
« Reply #1 on: July 01, 2006, 06:27:36 PM »
Don't know the size off the top of my head, but try a couple likely candidates and see which wrench fits.
Offline volz1fsu
Re: cam chain
« Reply #2 on: July 01, 2006, 08:25:44 PM »
Loosen the nut with a 10mm then it will automatically adjust.   After that is done, you hold the center threads with a screwdriver and tighten the nut again.
Offline 750goes
  • it will live
Re: cam chain
« Reply #3 on: July 01, 2006, 08:39:03 PM »
Loosen the upper nut closest to the cam chain tensioner main body, but only after you have set the motor in the right position for the correct tensioning of the chain...otherwise you risk releasing some tension from the chain, and then it gets noisy....
There is a correct procedure, probably written up in the FAQ somewhere..
Have a look in there first.
Not sure on the using the "screwdriver on the centre threads" method - can you give me some more info on that one "volz1fsu"
