Author Topic: So... this is bad, right? *Update on post #9*  (Read 6132 times)
Offline Dimitri13
  • 1974 CB550K
« on: September 19, 2012, 08:31:30 PM »
So the other day, I (believe I) spun a bearing. Engine still turns over and even ran, but had one helluva knock/click/tapping noise. Needless to say I didn't run it for too long. I had stopped to make sure there was enough oil in it (even though I knew there was because I just changed the oil and verified there was enough before taking off), a bunch of smoke came out of the filler hole.
I finally got outside to assess the situation. Drained the oil, and just as I thought, glitter.
Started tearing into the engine. First removed the breather cover, and verified the hose and tube wasn't blocked. Next came the tappet covers. All the adjusters looked to be fine.
Next came the valve cover. To my surprise, there was very little oil in the cam area. It looked as if my fresh oil had gotten in there at some point, but didn't stay there. Needless to say, the cam and rockers looked burnt up.
(same lobe, different angle)
(same rockers, different angle)
I didn't remove the cam yet, but the cam surface on the valve cover looks okay.
Are these damaged beyond reasonable repair?
« Last Edit: September 21, 2012, 08:17:03 PM by Dimitri13 »
Offline lucky
Re: So... this is bad, right?
« Reply #1 on: September 19, 2012, 09:51:21 PM »
The rocker arms look ok.
I do not see anything serious.
&50 or 550?
How many miles are on it??
QUOTE" I believe I spun a bearing??"  How can you tell such a thing?
Experts cannot tell unless they take it all apart and look at all the bearings.
« Last Edit: September 19, 2012, 09:54:06 PM by lucky »
Offline Flying J
« Reply #2 on: September 19, 2012, 11:49:26 PM »
yeah those look normal/good compared to some of the rocker arms i have. You could always try and drop the oil pan and see if you can see anything. Maybe your primary is rubbing... Dont know but dropping the pan is an easy thing to do before you have to start tearing things apart to find the problem.
Offline Dimitri13
  • 1974 CB550K
« Reply #3 on: September 20, 2012, 12:00:27 AM »
Well, something is definitely wrong, because those rockers didn't look like that last time I had the valve cover off.
That's a good idea dropping the oil pan. I would've continued tearing the engine apart and not even doing that :P
Although I likely will be doing a rebuild anyway.
« Reply #4 on: September 20, 2012, 01:13:30 AM »
maybe remove the alternator cover,,perhaps the rotor has come loose??check the clutch circlip hasnt dislodged aswell??might save a total tear down?
Offline Dimitri13
  • 1974 CB550K
« Reply #5 on: September 20, 2012, 01:23:12 AM »
Well, I'll be doing a total teardown for polishing/painting/rebuild anyway, but I'll make sure to check those thoroughly.
« Reply #6 on: September 20, 2012, 01:25:07 AM »
ok if your tearing it down anyway youll get to the bottom of it,,dont forget the pictures!!that top end wouldnt be making all that noise.
Offline Dimitri13
  • 1974 CB550K
« Reply #7 on: September 20, 2012, 01:29:11 AM »
Yeah, that's why I think I spun a bearing. It does look like the top end got starved of oil somehow. The rockers and cam look scorched, and there was a severe lack of oil when took the valve cover off. usually there's pools of oil underneath the cam, but it was nearly dry. So I'm thinking the top end overheated, and stuck a piston just long enough to spin a bearing, but not completely seize the engine.
Well, that's my theory at least. When I get to the bottom I'll find out for sure.
« Reply #8 on: September 20, 2012, 01:40:14 AM »
with a running engine the piston isnt going to stick without the engine slowing down and stopping,,it wont stick for a micro second,,lets see what you find,with the valve cover off crank the engine with ignition off,,you should see oil come from each end of the cam journals,,you might have a blocked oil restriction if it dosent flow on one side.
Offline Dimitri13
  • 1974 CB550K
Re: So... this is bad, right? *Update on post #9*
« Reply #9 on: September 21, 2012, 08:19:28 PM »
Alright so I tore the engine down more. I've removed the jugs. Rotating the rods on the crank, they all seem free, so I may be in the clear on the spun bearing idea. While tearing down more though, I think I may have bent the cam chain tensioner?
Then I dropped the oil pan and found basically metal sand (the big, gritty hawaiian sand)
I checked out the primary chain, I didn't see any evidence of it grinding into the oil passage, but it is LOOSE. I'm talking Paris Hilton loose.
« Reply #10 on: September 21, 2012, 09:30:05 PM »
some one might have bent that getting it in last time?pull the primary chain down and see if it can touch the case?
Offline Flying J
« Reply #11 on: September 21, 2012, 09:31:58 PM »
Are the shavings aluminum? or steel? looks like aluminum.
« Reply #12 on: September 21, 2012, 09:33:28 PM »
They slap around a lot when loose... cam chain can groove the passage through the cylinders wider, primary chain can cut into the cases in various areas.  Read the cb550/cb650 hybrid thread that Paulages put together. He installed the cb650 primary chain tensioner in the cb550 cases. Very slick solution.  How many miles on your motor?
Offline Dimitri13
  • 1974 CB550K
« Reply #13 on: September 21, 2012, 09:41:16 PM »
Dave, I had one helluva time getting it out and I believe I was the one that bent it (I bent the top a bit too pulling on it, but was able to bend it back). Is the bottom fixable? If so, have an example of how it should look? I'll be splitting the cases tomorrow so I'll see if it contacted anything.
ff, they appear to be aluminum.
RAF, I'll look into it. There was about 26k on the engine. About 17k from the first owner, and 3k from the previous owner (who severely neglected it), then the rest from me, and I ride hard.
« Reply #14 on: September 21, 2012, 10:00:13 PM »
dont try and remove that tensioner without lifting the barrel with it,you have to install it into the barrel then drop the barrel on the case aswell,,this is where the bottom can get mis cued and foul on the primary hub,your doing a good job,clean all the parts as you go,post some all angle photos of the tensioner,you should be able to gently bend it back,show us the face of the blade,they can be replaced,,the whole assembly is expensive as a unit,,i dont think the 500/550 cam chains can foul the case tunnel as much as the 750s can?ive had some pretty thrashed out engines and none have had cam chain tunnels worn?
« Last Edit: September 21, 2012, 10:02:12 PM by dave500 »
Offline Dimitri13
  • 1974 CB550K
« Reply #15 on: September 21, 2012, 10:15:15 PM »
Damn, really? My manuals didn't say anything about lifting the jugs with the tensioner, just remove the head, remove the locknut, and lift :/ When I get out there tomorrow to split the cases I'll get a picture of the blade. Should I also get a picture of the guide? The guide has a groove worn into it, but it's not that deep.
When bending it back, judging by pics on ebay, I should be bending just below the tensioner bolt where the sides look "flared out?"
« Reply #16 on: September 21, 2012, 10:26:37 PM »
Dave500, yeah I read 750 and 550 threads and have seen grooved case tunnels but didn't pay attention that it was a 750 issue. I haven't seen it on mine.  Read on some thread here that the 500/550 can need primary chains as early as 30-35k miles. Worries me some as mine has 31k...but no noises to be worrisome yet.
David
Offline Dimitri13
  • 1974 CB550K
« Reply #17 on: September 21, 2012, 11:03:22 PM »
I knew I needed a new primary chain because slop and lugging from a dead stop. I had planned on a full rebuild once I was employed again, and didn't think it'd be an issue waiting til then. Obviously I was wrong ~_~
« Reply #18 on: September 21, 2012, 11:59:11 PM »
Dimitri, I understand where you are coming from. I just got laid off myself. Took me 2 years to find a job the last time I was out of work. I really am not looking forward to anything ressembling the last time... Guess it might be time for going back to college.
Hawaii is an expensive place to live.
Good luck in your search and hope the rebuild isn't too pricey!  When we have the time we don't have money and sometimes the lack of employment and search makes it hard to be motivated to do anything.
Offline fastbroshi
  • Puppet
« Reply #19 on: September 22, 2012, 12:23:53 AM »
Whenever I'm tackling something paricularly complex or new I usually try to refer to my Clymer's and the Honda manual to make sure nothing's been left out of either source.
Just call me Timmaaaaay!!!
« Reply #20 on: September 22, 2012, 12:24:52 AM »
i just had a quick look at the honda workshop manual,at fig63 the caption states to lift the barrel 20mm to facilitate tensioner removal,i normally wiggle it up untill i can remove it,ive never seen that either untill now!
« Last Edit: September 22, 2012, 12:27:06 AM by dave500 »
Offline Dimitri13
  • 1974 CB550K
« Reply #21 on: September 22, 2012, 12:27:56 AM »
Hm... I had my honda workshop manual open, but I don't think I looked at it for this particular step, just my clymers -.-
« Reply #22 on: September 22, 2012, 12:30:15 AM »
i only have the downloaded 500 one which also has the 550 supplement?
Offline Dimitri13
  • 1974 CB550K
« Reply #23 on: September 22, 2012, 12:58:23 AM »
I downloaded whichever workshop manual is in the stickied manual thread.
Offline lucky
« Reply #24 on: September 22, 2012, 05:56:01 PM »
Just take it apart and you will find out.
Why even get everyone to tell you what they think is wrong when no one can say?
We cannot hear it ,we do not know its history- nothing.
