Author Topic: What's up with this Valve Cover?  (Read 1006 times)
Offline DJ_AX
« on: September 22, 2012, 04:26:10 PM »
I recently scored a replacement valve cover...
Gasket surface looks fine... clean and flat...
Thought it all was in great shape until I got a closer look.
Check out the pictures below...
I noticed these cracks on the inside by the tabs... they almost look like they might be just surface/stress cracks from casting. ???
Here's a close up of it
 I soda blasted the outside and saw no indication that it goes through... although the oxidation seemed so bad here it still looks like crap after that bit of blasting.
Here's a shot of a tab on the other side inside of the cover... I soda blasted it...
With this one it looks like you can see a line of oxidization right where the crack might be. ???
On the note of oxidization... this looks like it's got it really really bad...
Is this thing a lost case?  :-\
Offline tlbranth
Re: What's up with this Valve Cover?
« Reply #1 on: September 22, 2012, 04:29:54 PM »
Pour a little something that's real thin like gasoline & see if it seeps through.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: September 22, 2012, 04:31:03 PM »
Looks run of the mill to me.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: September 22, 2012, 05:41:53 PM »
+1
Look like regular casting marks to me.  Every sohc4 engine I've worked on has those in various places.
Offline lucky
« Reply #4 on: September 22, 2012, 05:47:05 PM »
Normal casting imperfections. Nothing abnormal.
« Reply #5 on: September 22, 2012, 05:52:25 PM »
you've got a lot of sanding to do to get rid of the oxidation, but with a lot of elbow work, it should look fine, I've found red scotchbrite works great...
Offline DJ_AX
« Reply #6 on: September 22, 2012, 05:56:00 PM »
Thanks... :)
