Author Topic: What wattage resistors to use on 3 ohm coils?  (Read 1914 times)
Offline Duke McDukiedook
  • Space Force 6 Star General
« on: September 25, 2012, 12:44:45 PM »
What wattage resistors should I use on my 3 ohm coils to raise the impedance to the coils?
I'll be buying some CL-80 thermistors for my tube amps and preamps and some other electronic parts I need to buy and I did not know what wattage Hondaman used in his resistor packs.
Offline luap
  • LAWL
Re: What wattage resistors to use on 3 ohm coils?
« Reply #1 on: September 25, 2012, 01:49:54 PM »
http://sohc4shop.com/catalog/product_info.php?products_id=44
thats got good info.
"The Dyna (Green) coils and ACCEL performance coils have 3-ohm primaries: these require a 1 ohm Resistor Pack to match these bikes' wiring (and charging) systems to those coils"
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
« Reply #2 on: September 25, 2012, 03:01:28 PM »
Well, I have the original points still but I hooked up a dyna-S system with 3 ohm coils and burned up the kill switch a good while back before I knew any better.  ;)
I just want to get it close to 5 ohm coils without wasting money on a whole set of 5 ohm coils.
I figured 10 watts is about what I would want but was unsure I would get 1 ohm or 2 ohm resistors until I actually measured the resistance on my current 3 ohm coils.
2 0hm
http://www.digikey.com/product-detail/en/RH0102R000FE02/RHRB-2.0-ND/1166282
1 ohm
http://www.digikey.com/product-detail/en/RH0101R000FE02/RHRB-1.0-ND/1166277
« Reply #3 on: September 25, 2012, 03:06:05 PM »
From that link you provided it looks like Mark uses 25 watt resistors, that would give a pretty healthy FOS as long as they fit and it looks like they do.
http://www.digikey.com/product-detail/en/RH0251R000FE02/RHRC-1.0-ND/1166295
« Last Edit: September 25, 2012, 03:12:04 PM by DukieFrankenkit »
Online scottly
« Reply #4 on: September 25, 2012, 06:55:33 PM »
P=IR2
1x1 = 1, 1x 3 = 3 Watts dissipated by the resistor when one coil is left on or two coils are operating alternately through the same 1Ω resistor.
P=I squared x R. 3x3=9, 9x1=9 watts dissipated by the resistor. The power dissipation would be less with the motor running, depending on the duty-cycle, or dwell, of the Dyna. For example, a 180 degree dwell would equal a 50% duty cycle. .5 x 9= 4.5 watts.
« Reply #5 on: September 25, 2012, 07:07:30 PM »
P=IR2
Dyslexia strikes again.   :(
Online scottly
« Reply #6 on: September 25, 2012, 07:13:35 PM »
I know the feeling! LOL ;D
« Reply #7 on: September 25, 2012, 10:03:40 PM »
I use 10 watt resistors: the picture on my website shows the ones (25 watt) that I had to use during 2008 and 2009, when the entire world's inventory of 10 watt aluminum resistors in 1.0 and 1.2 ohms was gone, and no one was planning on making them soon(!). I used all those up, back to the smaller 10 watt units again. Thank goodness for Ohmite stepping back up to fill in the gap!
« Reply #8 on: September 26, 2012, 07:37:36 AM »
Thanks guys, I would buy them from you Mark if I wasn't buying parts for some audio vacuum tube equipment I am recapping for some rebuilds.
Time does not wait for electrolytic capacitors.  :)
« Reply #9 on: April 14, 2013, 11:32:25 PM »
Is my assumption correct to connect the resistors to the black wires and then to the coil from the positive side of the battery?
