Author Topic: Frame identification  (Read 1332 times)
AustralianShepard
« on: October 01, 2012, 07:49:07 AM »
Is there a way to identify the frame if the VIN plate is missing?  Is the VIN stamped into the frame somewhere?  Any info would be appreciated.  Thanks
Offline mcpuffett
Re: Frame identification
« Reply #1 on: October 01, 2012, 08:16:43 AM »
Hi all of the frames should have the number stamped in the headstock on the left handside  ;),
when you find the number you can check on this website to see what you have  ;), cheers Mick.
 http://www.ace.net.nz/classic/numbers.htm
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: October 01, 2012, 03:35:51 PM »
OOps, I stamped mine on the right.  :o
AustralianShepard
« Reply #3 on: October 05, 2012, 04:55:41 PM »
Thanks for the info, it is a 74 K frame.  It has a removable section of frame above the cylinder head.  Is that stock, or an aftermarket weld on part?
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #4 on: October 06, 2012, 02:36:56 AM »
Aftermarket due to laziness and past top end engine work.
« Reply #5 on: October 06, 2012, 05:01:00 AM »
Another ridiculous comment. The frame kits allow the head to be removed whilst the engine is in the frame, if its a quality frame kit then the frames integrity stays intact, rather than the stupid lazy comment, it is a much better way to work on the engine whilst in the frame and saves a lot of trouble , the usual method of having to remove the engine to work on it is a pain in the butt... ;)
Later model Honda's {and other models} like the 900 Boldor have a removable frame downtube to allow easier access to the engine...
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #6 on: October 06, 2012, 10:26:44 AM »
I would never cut a frame just to do top end work.  laziness.  I can remove and replace an engine in less than an hour.  When you add a so called "kit" to remove and reinstall the frame tubes all you have is a cut frame, reduced resale value, and proof that you don't understand, or are too lazy, to do the job right.  I always repair frames like that by welding back the butchered sections.
« Reply #7 on: October 06, 2012, 11:59:59 AM »
If you are referring to a CB750, I would bet a large sum of money against.
« Reply #8 on: October 06, 2012, 03:08:01 PM »
Good for you..... ::)
So all the motorcycle manufacturers that build removable frame rails into their bikes are lazy.... :o
This is quite stupid and hypocritical coming from someone that then cuts the rear of the frame off to make the bike a rigid.... Kinda says it all eh....
Do you ever actually read the crap you write ?..... ::)
Online HondaMan
« Reply #9 on: October 06, 2012, 08:24:36 PM »
Takes me half a day! :(
