Author Topic: CB500 Front Brake (MC?) again... incorrect piston?!!!  (Read 1703 times)
Offline Yazbulls
« on: October 09, 2012, 01:31:10 PM »
Hi All
Go easy on me, first time on one of these forums.
Apologies if this has been covered elsewhere, but if the specifics I will mention have, then after hours searching I've not found it! My explanation will probably be long, but I'm hoping that in response all I'll need is a quick  'yup, you're right!' and that my description and any responses will also help others.
I am in the process of restoring a 1976 CB500T...the front brake is I believe the same as those on the 1970s SOHC 4s. No matter what I do the lever goes back to the bars and although the front brake operates and releases again, there is not quite sufficient stopping force.
I am pretty certain that I need to rebuild, or perhaps better replace, the MC but before splashing out any hard earned dosh wanted to see if there was agreement that I had got it right.
So in summary, there are only a limited number of components that could be faulty, the caliper, brake hoses, and MC, plus  the brake fluid.
I've done numerous tests to try and determine which part is at fault, and on the face of it, individually each is okay, they just don't work together...weird...but hopefully I've fathomed it out and my conclusion at the end is good?
Okay, so I'd broken the bleed nipple off the original caliper. Local company that specialise in vintage vehicle brakes removed the old nipple and replaced it, plus fitted a new seal and piston.....so the caliper is probably now better than new.
The rubber brake hoses looked fine, no sign of ballooning, and there was no leaks at any of the joints, or from the MC or refurbed caliper.
Refilled with fresh dot 4 brake fluid, bled the air, and tried the brakes, which I cannot get any better than I mentioned at the start. So I started trying various tests.
Firstly, no amount of pumping on the lever improves the braking, which I believe confirms there is no air in the system, as if there was I could have temporarily pumped the brakes up. I tried everything bleeding anyway, including using gravity, then clamping the lever back partially overnight to allow air to escape.
If I clamp the bottom hose just before it enters the the caliper, and try to pull the lever it is rock solid. I believe this confirms that the hoses and joints throughout the system must be fine (and also no air between MC and clamp).
I also believe that this test is supposed to confirm that the seals in the MC are  good.
So at this point, all the components appear to be good, yet put together the brake is rubbish.
Next, I wondered if the connector block between top and bottom hoses was the problem. So I removed the master cylinder, mounted it on a piece of pipe in lieu of the handlebar, and connected the bottom hose directly into the MC, and bled the system.
The feel of the brake like that is exactly the same as when the whole system is connected, which I believe confirms that there is not a problem with the top hose or connector block/brake light switch.
If I clamp the hose, anywhere but not quite so tight that it is completely blocked off but tight enough that it effectively creates a non return valve, I can get enough pressure into the system after a second pull on the lever to get sufficient stopping power into the brakes.
Just to clarify on this test, the clamp is only fractionally less tight than with the hose fully 'squeezed'. With a good strong pull on the lever fluid can be forced past the clamped part of the hose, but there is not sufficient return force from the caliper to force fluid back past the clamped bit.
Looking at the caliper when I do this, on the first pull of the lever the piston/pad moves out of the caliper the same amount that it would normally without the clamp, but does not then return when the lever is released. On a second pull of the lever, which will now only travel a relatively small amount (nowhere near to the bars), the caliper piston/pad moves out a shade more and grips the rotor like it should.
I believe this test confirms that the caliper is working okay, but could suggest that the hoses are expanding, or seals inside the MC are shot. However, the integrity of the hoses and MC seals has already been confirmed by the lever becoming solid on full clamping.
So at this point, the various tests suggest nothing wrong with any of the components, yet the brake is till absolute rubbish.
However, somewhere on another thread on here I think I found the answer to this  mystery. It was suggested that some MC repair kits come supplied with pistons that are an incorrect length, and whether too long or short can cause problems.
If too short, there is loads of travel before the relief hole is covered, so only the final part of the piston movement generates any real pressure in the system.
If too long, there will not be enough movement before it hits the stops to generate sufficient pressure in the system,  plus as the relief hole might permanently covered, once applied the brakes will not be able to release, same as if that hole were blocked with crud.
Both possibilities would give similar problems with lack of system pressure and thus braking power.
My caliper releases just fine, so I am starting to think that a previous owner has rebuilt the MC using a kit where the piston is too short. The last owner has confirmed that the front brake was always well below par, and that it must have been someone before him that rebuilt them. if indeed that was done.
Also, when I take the reservoir cap off, fluid squirts quite violently back up from the relief hole throughout most of the pull on the lever, which I think again suggests that the piston is too short.
So my conclusion is that the MC has probably been rebuilt at some stage with a piston that is too short. Even if that theory is wrong, the various tests tend to confirm that there is nothing wrong with the caliper, hoses, and that there is now air in the system, so the only thing left to repair/replace is the MC.
If there is agreement that the problem appears to lay with the MC, I think I'll just get the pattern replacement from David Silver as it is only marginally more expensive than the repair kits but avoids the hassle of getting that flipping circlip out, the chances of messing up, or being supplied with the wrong piston.
Does it sound like the MC is at fault and if so due to an incorrect piston or some other reason, but if not, has anyone any other suggestions for what is wrong?
If you have got to the end of this essay, well done, and thank you so much and you deserve a long cool beer....cheers.
Thanks again for your help
Yaz
Offline Yazbulls
Re: CB500 Front Brake (MC?) again... incorrect piston?!!!
« Reply #1 on: October 09, 2012, 01:38:26 PM »
Towards the end, apologies for the typo. Meant to say, 'there is no air in the system, not 'there is now air in the system'....only a slight difference there then when it comes to hydraulic brakes...LOL!
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: October 09, 2012, 01:42:47 PM »
Have you verified both holes in the master cylinder are clear?
Remove the caliper and clamp the piston so it does not push out, this will verify that the caliper is not the problem.
« Reply #3 on: October 09, 2012, 01:50:09 PM »
with the cap off and the lever actuated it will spurt a little jet out,is the rubber cup on the master piston backwards?
Offline Yazbulls
« Reply #4 on: October 09, 2012, 02:38:55 PM »
Thanks for replies already...great
@Lester Piglet....yup....both holes in the master cylinder appear to be clear
@ Dave 500... the only thing I haven't yet done is dismantle the master cylinder as I cannot get the damned circlip out....it seems to be rusted in, and the one end snapped off.....so don't know if the master cylinder cup is around the wrong way. However, the spurt when I pull the lever with the reservoir cap off is massive and prolonged....hence my concerns about the piston being shorter than it should be.
The main thing I guess is does everything suggest that the problem lies with the MC? If it does, then the simplest solution is just to replace it, especially since I can't get the damned thing apart to repair?!!!
« Reply #5 on: October 09, 2012, 05:15:31 PM »
forum member here frosty uses the david silver replacement,ive seen it and they are good,certainly if yours is rusty around the clip etc just get a complete new one,those clips are a fiddle even when its all clean and clear!
Offline JohnG
  • 1976 CB750F - original owner
« Reply #6 on: October 09, 2012, 05:22:47 PM »
I just rebuilt the master cylinder on a CB450. Probably identical.
The circlip broke off for me as well.  Snap ring pliers dont work for getting these out.
I put it in the vice and had it upright.  Put  Liquid Wrench in overnight.
Next day I got a screwdriver and a pick.  I pushed the piston in with the screwdriver which gave me some room to work.  I worked the snap ring looose with the pick  (in the one remaining hole).  Once loose I pried it inward until some of it came out of the groove.  This was trial and error for a good 15+ minutes.  Once out of the groove I  was able to pull it farther and farther out until I won.
Now before you do all this you might remove the upper hose, put your finger over the 10mm opening and pump away.  This gets you some real information fast.
However this thing is 30+ years old and deserves to be rebuilt after careful cleaning.  The kit is pretty cheap and it removes one possible failure.
Wish I could say I have a fast way to get all the air out of the overhauled system . . .I am as far as a spongy brake but will win eventually. So will you!
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
  • 1977 CB550F2
« Reply #7 on: October 09, 2012, 05:45:37 PM »
I also use the David Silver replica MC. I thought, it's the same price as a repair kit why not? The only difference to the original is it is all metal. Works perfect.
Offline Yazbulls
« Reply #8 on: October 10, 2012, 01:51:40 AM »
Thanks again for all the replies. Its good to hear that if all else fails the David Silver pattern replacement MCs are good.
Before ordering one I will just have  a final go at bleeding the system, but since the feel does not improve with pumping I'm pretty confident that all the air is already out. Also, if that fails I will try the suggestions to get the circlip out and take the MC apart as I would feel so much better replacing it if when I looked inside I could see that it was a mess, or that the piston was the wrong length. Incidentally, I know the bore is 14mm but does anyone know what length the piston should be?
Finally, something I haven't mentioned is that there is something like 5mm-10mm play in the lever before it actually engages at all on the MC piston which seems a bit odd to me and tends to suggest that movement at the lever that could be turned into hydraulic pressure and thus braking power is simply not being utilised. Should there be that much freeplay, as I don't recall levers on other bikes I have had having that much. Indeed, on my other bike, a 1989 VFR750FK the free play at the lever before it engages is minimal.
Cheers
Offline JohnG
« Reply #9 on: October 10, 2012, 10:45:43 AM »
the free play would annoy me.  One more reason to rebuild or replace the MC.
I have no experience with the David Silver Spares repro MC but their other repro items that I bought have been first rate and I take them as pretty serious about such things.  I try to refurbish original stuff but I would be perfectly happy to use one of their MC's.  Basically it is just a bore with a couple of strategic orifices in it so should be fine.
1971 CB450
1979 CB750F
1982 CB900F
Offline SohRon
« Reply #10 on: October 10, 2012, 04:34:51 PM »
You might be missing the rubber lever stop; look underneath the MC. There should be a small metal plate or, if it's missing, a hole near the lever attachment. There's a rubber tube that fits in there that acts as a bumper for the lever, it's actually just a short piece of vacuum hose. That could account for the lever play.
Offline Yazbulls
« Reply #11 on: October 10, 2012, 06:08:53 PM »
SohRon - Although I guess it makes no difference to the actually braking efficiency at the caliper that's interesting. Yes, underneath the MC there is a metal plate, It appears to serve as a washer to the lever pivot bolt nut but also has a smal 'nipple' that fits into a small indent on the underside of the MC. The plate, or 'glorified washer' appears to serve no real purpose to me....but yours was the first mention of it. However, I can't quite picture how the lever bump stop might be fitted or of what benefit it might be apart from stopping the lever flapping around?
« Reply #12 on: October 10, 2012, 06:34:18 PM »
I probably have 6 or 7 various sohc4 mc's in the garage, and not one of them still has that bump stop thingy...in fact, the only place I have ever seen it is pictured on here
Offline SohRon
« Reply #13 on: October 11, 2012, 05:26:54 AM »
Remove the plate, insert some vacuum tube (or fuel hose or whatever) of the right diameter into the hole under the dimple, cut it off level with the MC body, then reinstall the plate. Either that, or you can actually purchase the part from Honda for $5 plus shipping. I would think keeping the lever from flopping around would be sufficient reason to replace it...
Sounds like you need to buy some vacuum tubing! After '76 they modified the MC and eliminated the stop.
« Last Edit: October 11, 2012, 07:08:21 AM by SohRon »
