Author Topic: Felt Rings for swing arms, here you go  (Read 3121 times)
Offline ncstatecamp
« on: October 18, 2012, 06:51:27 AM »
As the title says if you are rebuilding your swing arm and are in need of compressed felt for the dust seal the inner ring of these sets fits fairly well. I got mine at advanced auto. Just make sure they are the kind with 2 sizes that come apart as the inner ring will fit but the outers are way to big.
http://www.autozone.com/autozone/accessories/Duralast-Large-felt-battery-terminal-protector/_/N-255s?itemIdentifier=8170
I had been told to get some and just cut my own but no where I went has compressed felt.
Re: Felt Rings for swing arms, here you go
« Reply #1 on: October 18, 2012, 08:06:42 AM »
Nice one!
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: October 18, 2012, 08:50:07 AM »
Yeah, well done! Now, if we could just find these that fit in 750 PD carbs...
Offline ncstatecamp
« Reply #3 on: October 18, 2012, 09:39:53 AM »
PD carbs?
Offline ncstatecamp
« Reply #4 on: October 18, 2012, 09:40:27 AM »
Admittedly they are a perfect fit but they'll work well enough.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: October 18, 2012, 11:10:27 AM »
As in: the carbs that came on 77/78 750F & K bikes.. they have felt washers that go either on the throttle linkage or the choke linkage - can't remember which. But either way, you can't find 'em and if you mess yours up you're screwed.
Offline ncstatecamp
« Reply #6 on: October 18, 2012, 12:14:46 PM »
No way to get a sheet and exacto them out?
Offline CycleRanger
  • No comment about being an
« Reply #7 on: October 18, 2012, 03:26:02 PM »
I thought those were impregnated with some chemical to prevent corrosion?
Honda still sells the felt rings for the swing arm btw.
Offline ncstatecamp
« Reply #8 on: October 18, 2012, 04:42:45 PM »
I didn't feel any residue, I think their meant to block air and cushion from the terminals wiggling causing sparking/oxidizing. I stopped by 2 Honda dealers and both gave me stupid looks and tried looking them up with nada.
« Reply #9 on: October 18, 2012, 04:46:48 PM »
That's not uncommon! They are available, though, about $2 (plus $10 shipping!).
Offline mono
  • Definitely no
« Reply #10 on: October 18, 2012, 06:18:31 PM »
I planned on punching my own with craft felt...
 Was going to use yellow felt for extra horsepower.  ;D
Sent from my SPH-L710 using Tapatalk 2
Offline CycleRanger
« Reply #11 on: October 18, 2012, 06:46:45 PM »
Yeah, well that doesn't surprise me.  It's PN 52145-283-000.
I'm pretty sure those battery felts do contain some sort of chemical to inhibit corrosion.
Whether or not that's an issue I don't know.
« Last Edit: October 19, 2012, 06:04:09 AM by CycleRanger »
« Reply #12 on: October 18, 2012, 11:07:54 PM »
 If you can find the felt, should be easy to make a cutting die..
« Reply #13 on: October 18, 2012, 11:57:54 PM »
Come on Mono, everyone knows red is faster than yellow.... 8)
« Reply #14 on: October 19, 2012, 01:58:36 AM »
hey!!,how come my new red felt hat has heaps of holes in it?
Offline mono
  • Definitely no
« Reply #15 on: October 19, 2012, 06:09:10 AM »
THE DEBATE RAGES ON.....  hahaha.
