Author Topic: understanding the "simplified" wiring diagram, and adding to it?  (Read 3241 times)
bollingball
Re: understanding the "simplified" wiring diagram, and adding to it?
« Reply #25 on: October 30, 2012, 04:48:34 PM »
He is using the rear fender as ground. It should go back to the frame. You need to put a green wire from the light to the coil mount bolt. Where ever you put the ground make sure it is bare metal. You could put it at the rear engine mount bolt.
Ken
Offline jason41987
« Reply #26 on: October 30, 2012, 04:51:39 PM »
ok.. i figured it was grounded to the frame via its mounting it to something metal, but wasnt sure... glad someone could verify it
