Author Topic: CB550 front end on a cb500?  (Read 1378 times)
green500
« on: July 09, 2006, 12:01:51 PM »
Will a '78 cb550 front end -triple tree, steering head, and fork system work on my '71 cb500 ?  Will the steering stem fit into my frame, will it modify the ride ht. or handling on the bike?  Mount my same wheel, caliper, fender...
any ideas how I can find this out on a sunday.
Some one has all the gear I need on ebay and i found my self tearing down my entire front end yesterday- one problem leading to another...
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: CB550 front end on a cb500?
« Reply #1 on: July 09, 2006, 12:53:14 PM »
                           Far as I know, they are the same. As far as fitting, you can put the SOHC750 forks complete on a 500/550 too. There might be some difference with the 750 but, I don't see how the 550 onto the 500 would make a difference. Need some more experienced input here! If I'm right, basically , the 550 is an improved and slightly enlarged (engine displacement wise) and improved in the clutch area too. Don't know if that helps. Later on, Bill
Member # 1969
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #2 on: July 09, 2006, 01:04:12 PM »
I am using a late model (can't remember the year)  550 front end on my 73 500.
I am just using the fork tubes and sliders with my
original tree and that is a perfect fit, so I would
guess the trees are the same.
Generally most 500 frame parts are swappable
with 550 parts.
lots 'o luck pal!
Bikes parked out front mean good chicken-fried steak inside.
