Author Topic: Things you FORGOT to do on your rebuild (or what do you feel dumb about :0 )  (Read 5909 times)
OK- here goes, I was young and it was the 70s, so...
I was tasked with building a CB750 from parts in the shop for resale. I really didn't know what i was doing. I put the swingarm on, leaving out the collar.
Took it for a test spin. Didn't take much throttle to move the swingarm, luckily it didn't have far to go. A little body English kept it from going down.
Shheeesh.   :-[
Offline Blitzburgh207
I got roughly 5k out of my rebuild last year before losing 5th gear..... after splitting the cases for a look around and comparing to parts diagrams I found that I was missing the two locating rings (#1 in the diagram) and it had shifted enough that 5th couldnt engage all the way (hence the nasty grinding sound). smh.
All I can think of is I must have thought they were a couple broken piston rings I had lying around to clean the grooves out with and I just tossed them.....good thing I have a spare!  ::)
1978 CB750 K8
Offline Lostboy Steve
Didn't get a front sprocket bolt tightened enough, and invented a crude form of O-ring chain CNC routing.  Caught it in time before it did any damage (other than bruised ego) and created a special "limited edition" circular groove around the output shaft seal.
I love this...
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
I call that "self-clearancing" 8)
but... I love this even more! lol good form!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
MC actually turned billard terms into rider maneuvers.. "Rider English" You, my friend, just coined a phrase that i will use until it is sickening.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
We always called it body English as far back as i can remember. Usually leaning the body one way and the bike another, especially a dirt bike, standing on the pegs.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
I rebuilt my carbs a couple summers ago. Got it to idle perfect, turned the petcock off and shut the bike off. Had some dinner with the wife, told her I was going to take a spin to check out how it ran in the upper RPM's. Well got it out on the road ran it up , well I tried to run it up, but... I had the petcock still in da off position. She doesn't run very well with no gas...... Duh  :-[
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline andrewk
  • doin' it.
Shheeesh.   :-[
Similar story from my younger days...
I changed swingarms on a Kawi twin I used to have.  The swingarm had bushings that ran on a steel sleeve that ran the length of the swingarm, and the bolt went through the sleeve.  Once the bolt is tight, you have  bearing surface.
The used swingarm I purchased didn't have the sleeve, and I didn't notice the sleeve in the old one.  Rode it around a bit, couldn't figure out why the frame felt like it was on hinges.  Put it on the center stand and D*OH. :)
