Hi all, Thanks to your good info, (and a Clymers manual) I have a stock, 9/72, CB350F back on the road! Also has a Martek440 electronic ignition? NOT stock.
Only problem is now I have power problems...
1. I cleaned the gas tank with molasses
2. Installed in-line filter.
3. Charged the battery,
4. Set valve clearances,
5. Checked spark and good spark on all four cylinders.
6. Checked cold compression and all were reading about 160 +/- psi.
7. Drained carb bowls and confirmed fuel flow to all four bowls.
Went to start and YEAH!! there she goes!
Although, cylinder number four does not fire reliably--the header pipe does not acheive the same temp as the other three. Pulled the plug again to confirm spark, and it gave sparks, but was also dark, gas smelling and slightly wet.
All the plugs are dark, and I have no good accelleration and under load it struggles to go past 5000 RPMs
Any tips as to what the next step should be? Why would one cylinder not fire when it gets spark and fuel? What do I need to check next?
Thanks!
