Author Topic: Original camshaft ?  (Read 3649 times)
Offline Hummel
Original camshaft ?
« on: February 03, 2013, 04:30:46 AM »
How can I tell its an original camshaft I have in my cb750 1974 ? It have an mark saying " made in USA" isn't that strange sins it an Japanese bike ?
Best regards Tommy Hummel
Sent from my iPad using Tapatalk HD
Offline Dream750
Re: Original camshaft ?
« Reply #1 on: February 03, 2013, 05:33:36 AM »
Original Honda 750 K & F cams will be “R” marked next to the cam sprocket. I have several examples and seen them marked anywhere from R1 to R12.
Sounds like you have an aftermarket cam, do you see any other markings besides made in USA?
« Reply #2 on: February 03, 2013, 06:09:50 AM »
Sounds aftermarket. What do the top of the pistons look like,are they flat or do the have a dome for more compression. If its apart I would measure their diameter to see if you have a big bore kit in there. Do the valve retainers look stock also. Pics are usefull and fun also.
Offline Hummel
« Reply #3 on: February 03, 2013, 06:31:26 AM »
The pistons is 61mm in diameter and flat in the top. I Would try to take soms pics when I go to the garage again. Thank you
« Reply #4 on: February 03, 2013, 06:36:22 AM »
Cam is a Kenny Harmon "D" grind
Offline 74750k4
« Reply #5 on: February 03, 2013, 09:01:03 AM »
That sure is a KHD. Which would make that cam a re-ground Honda part, since it has that R1 mark too!
I'm installing a KHD (from Dynoman Perf) in my 74' engine right now, with 78' P/C, 392 head, Kibblewhite springs, CycleX Superflow valves. Std. bore. Special head work, by Ken Augustine... http://www.motorcycle.com/how-to/modifications-to-the-henning-honda-cb500-14679.html
Anyone running a KHD out there? Would love to hear all about it!
Offline Dream750
« Reply #6 on: February 03, 2013, 09:51:45 AM »
Guys, I apologize for any confusion on the Cam markings. :(
The intent of my post in reply #1 was to show the OP two different photo examples of cam markings and where to look. As these are two seperate 750 cams.
First photo: How an original Honda 750 cam is marked with the “R” number next to the cam sprocket.
Second photo: How aftermarket 750 cams are often marked at the end of the shaft as in my Kenny Harmon “D” example.
As a side note: My K/H “D” is a regrind and was originally a Honda cam marked R8 and does not have the “Made in USA” mark.
Offline Hummel
« Reply #7 on: February 06, 2013, 09:27:53 AM »
Here are some Pics. Can you say something about this cam! At the end it say ANDRWD
« Reply #8 on: February 06, 2013, 10:07:09 AM »
I can't see the pictures, but I would guess that is an Andrews "D" cam.
http://www.webring.org/l/rd?ring=thehondasohc4web;id=1;url=http%3A%2F%2Fwww.satanicmechanic.de%2F
Hmm, the link didn't work the way I wanted.. Anyway, there are specs for the Andrews cams on the santanic mechanic site...
« Last Edit: February 06, 2013, 10:09:52 AM by scottly »
« Reply #9 on: February 06, 2013, 10:12:53 AM »
My computer does not open the pictures either   :'(
Offline Hummel
« Reply #10 on: February 06, 2013, 12:24:12 PM »
No my Picture uploader dosen't work. I will try to get that going later.
But Andrews D cam sound about right  :)
Offline Dream750
« Reply #11 on: February 06, 2013, 06:53:52 PM »
This is how my 750 K Andrews “A” cam is marked and the “made in USA” is not present.
Other markings present are: C.M.C., C1, D1, 2187 and C1 once again. There is not any evidence of the cam being a regrind.
Offline Hummel
« Reply #12 on: February 07, 2013, 01:43:48 AM »
So this cam could be stock grind ? No performance at all ?
Offline Dream750
« Reply #13 on: February 07, 2013, 04:27:49 AM »
Your Andrews “D” looks right as they had the EP-13 mark and it’s a performance cam. ;)
« Reply #14 on: February 07, 2013, 05:03:44 AM »
I have an Andrews in an RC836 I did many years ago,can't even remember what it is anymore  ::)
   That aside though be sure to check what the valve lash should be set at. Without digging for my old instructions I think mine was to be set at .004 for both the intake and exhaust not the .002/.003 spec for a stock cam.
