Author Topic: Airbox's there is a difference. (Pics) Which one you would use?  (Read 1480 times)
Offline 78 k550
« on: October 17, 2007, 02:12:48 PM »
Hey All,
I just picked up a used airbox for my 750F well I got it home and it is different from the one I have.
Look's like there is a difference's for the 77-78 F vs the K
Paul
« Last Edit: October 17, 2007, 07:33:29 PM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
Re: Airbox's there is a difference. (Pics)
« Reply #1 on: October 17, 2007, 02:19:45 PM »
Here is a pic of the #'s.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
Re: Airbox's there is a difference. (Pics) Which one you would use?
« Reply #2 on: October 17, 2007, 07:37:47 PM »
in the pic #2 the PO cut out a little extra plastic to let it breath a little better.
I'm thinking going with the F model. I wish the K&N I have fit it is just a wee too small, like it shrank a bit. Im thinking of picking up a UNI Filter for it.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #3 on: October 17, 2007, 08:52:15 PM »
The later model runs quieter, which is what that bottom snout is about.
The earlier ones breathe a little better, but make more noise.
Offline 78 k550
« Reply #4 on: October 17, 2007, 08:59:22 PM »
Thank's
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #5 on: October 17, 2007, 10:17:13 PM »
Paul,
I have a K & N in mine?! If I remember correctly it is a snug fit on the flange that the base of the filter sits on but it worked.
If any of you guys have a good gasket that goes between the 2 air box pieces I could use one. Do both boxes use the same gasket?
Offline 78 k550
« Reply #6 on: October 17, 2007, 11:19:08 PM »
Doesn't apear to be the same. the 77 box has a gasket that fits snug in the top piece. the earlier one had a piece wrapped around the bottum piece.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
