Author Topic: Exhaust rings  (Read 2093 times)
Offline Madman9050
Exhaust rings
« on: February 15, 2013, 03:56:52 PM »
This info may be somewhere else on the sight but I'm gonna ask anyway my 77 750f had an aftermarket pipe on it which had its original mounting rings replaced with a set that were attached to the pipe. So when the pipe rusted out I replaced it with another that doesn't have the rings attached so I thought I would cut some out of aluminum but I need the correct ID and OD and bolt spacing so if anyone knows please help
when your vision gets blurry and the white lines come together when your heart is pounding and you cant take anymore,catch another gear
Re: Exhaust rings
« Reply #1 on: February 15, 2013, 04:41:18 PM »
Is it just the round crush gasket ring you need.?   Set of 4 is cheap to just buy without the hassle.  http://www.ebay.com/itm/HONDA-CB750-SOHC-EXHAUST-GASKETS-/200880551082?pt=Motorcycles_Parts_Accessories&hash=item2ec569f4aa&vxp=mtr
Offline wowbagger
  • Not much of an
Re: Exhaust rings
« Reply #2 on: February 15, 2013, 05:17:16 PM »
Re: Exhaust rings
« Reply #3 on: February 15, 2013, 05:18:55 PM »
Hey Eric, I think he's referring to the ex pipe joint, #2 in the fiche.
Is that really the name??
http://www.westernhonda.com/fiche_section_detail.asp?section=2560114&category=Motorcycles&make=Honda&year=1974&fveh=132838
Should be easy to find here or eBay. I don't have em for an F
Offline Madman9050
Re: Exhaust rings
« Reply #4 on: February 15, 2013, 05:49:09 PM »
yes #2 is the exact part im asking about
Re: Exhaust rings
« Reply #5 on: February 16, 2013, 04:30:08 AM »
WHOOPS - sorry,should have known it wouldn't be that easy. Here is a bump back to the top.
Offline bjbuchanan
Re: Exhaust rings
« Reply #6 on: February 16, 2013, 05:21:08 PM »
So you need a set of exhaust clamps for a spigot type exhaust system? You need some beefy clamps not sheet metal straps more or less
If so pm about it I have another set
Re: Exhaust rings
« Reply #7 on: February 16, 2013, 08:21:48 PM »
Being a 77 it should not use the spigot style.
Offline Madman9050
Re: Exhaust rings
« Reply #8 on: February 17, 2013, 06:23:05 AM »
right it has studs in the head and two little inserts on either side of the pipe and a ring that holds it all down ill have pictures later of some i cut out but im having problems getting the bolt spacing correct
Offline Madman9050
Re: Exhaust rings
« Reply #10 on: February 17, 2013, 05:45:05 PM »
i made these up today what do you think?
Offline bjbuchanan
Re: Exhaust rings
« Reply #11 on: February 17, 2013, 05:47:33 PM »
I like them, do they work?
Offline Madman9050
Re: Exhaust rings
« Reply #12 on: February 17, 2013, 05:58:18 PM »
everything seals up good so far once i get my carbs synced and the tank finished ill get a few heat cycles on them then ill see if they'll work
Offline bjbuchanan
Re: Exhaust rings
« Reply #13 on: February 17, 2013, 06:33:30 PM »
How thick is the clamp?
That will prob determine if you are gonna heat cycle them to death. My eyeball measurement would say 3/8" or thicker would make a suitable flange atleast minimum. They gotta be thick to dissipate that heat
Re: Exhaust rings
« Reply #14 on: February 17, 2013, 06:35:55 PM »
Did you change the gaskets? If no, they will most likely leak.
Offline Madman9050
Re: Exhaust rings
« Reply #15 on: February 17, 2013, 11:01:44 PM »
The pipe that was on the bike when I got it had some stamped steel clamps that couldn't be removed from the pipe I ended up cutting them off and using the two halves to hold the inserts in. That worked great for almost two years I just wanted something that was a little more attractive
Re: Exhaust rings
« Reply #16 on: February 18, 2013, 04:51:14 AM »
Wonder if the fact that the stock clamps are a finned heatsink would help keep down the temps a little around the exhaust valve area of the head. Probably not enough to make any difference but something for our engineer types to ponder. Hmmm
Offline SohRon
Re: Exhaust rings
« Reply #17 on: February 18, 2013, 05:36:45 AM »
+1  Just wondering just how much the stock joints work to keep the headers cool.The fins give it quite a bit of cooling area that a flat washer lacks. I'd think blued pipes would be a result, at least (although yours are wrapped),
