Are you talking about the seal under the top cap? If so, is it rubber or a fiber? It probably is still available. If it is rubber, then you just need to get an o-ring aboutthe same size to put on. It does not come in contact with gas so any rubber should be fine. Otherwise, most quality carb kits have them too but then you get a whole kit which is expensive but the bright side is that you have parts for later.
