Sorry for not updating.  I was going to let this go until I had some testing done on these to share, but since you asked
.  I ended up custom boring a set of carbs from my stash using the dimensions from Frank's(754) vintage bored set as a guide(thanks Frank).  I didn't go quite as radical as Frank's set, but these carbs are intended to be more street friendly.
The factory carb actually measure out to an equivalent of 27.7mm throat, and my bored carbs measure out to 29.4mm(Frank's set was 30.4mm!).  Bill Benton has an interest in testing them and comparing them to factory stock carbs, so at some point we might be able to gather some useful data and see how they compare back to back on the same engine.  He currently has them.  Bill has a full racing schedule, the Tiger to work on, and plenty of other things going on, so it may be a while before this experimental side project gets going.  No rush here...
I'm not sure where this will all end up.  I'm thinking of it as a fun experiment.  No more, no less.  I have no expectations that these bored factory carbs will be the next hot ticket or anything.  Hopefully they will show an improvement over stock carbs on engines powerful enough to benefit from an increase in throat area and not mess things up at the low/midrange end of things...
We'll see.
George
