Author Topic: Before I damage my carbs  (Read 2099 times)
Offline goldarrow
  • one day, i'll be an
« on: March 08, 2013, 12:33:24 AM »
Back story: few weeks ago I picked up a 76 550k bike with stock carbs 087A.  And while going through the usual routine, getting the carbs clean, found that float pin post on #4 carb is broken. Much reading found that 022A carbs is closest fit, so I pulled it out of my parts bike.  And here it is
Nicely gummed up with old gas.  Took the jets out fine, but having problem taking out the float pins, all 4 of them won't move, and I don't want to break the posts.
So, what would you do?
CB550 K0
Offline prov431
  • '76 CB550K
Re: Before I damage my carbs
« Reply #1 on: March 08, 2013, 12:40:31 AM »
You could try soaking them in solvent overnight, that might loosen them up. Perhaps a little heat after the soak if they're still tight?
Offline goldarrow
« Reply #2 on: March 08, 2013, 12:43:35 AM »
I was thinking of doing that, but unsure of soaking the whole rack or take them apart.  Really have no intention of taking them apart.
CB550 K0
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: March 08, 2013, 12:56:41 AM »
A heat gun in conjunction with the proper size pin punch and, yes, the carbs will need to be apart to get at the inner two...Larry
« Last Edit: March 08, 2013, 01:20:50 AM by MoMo »
Offline phil71
« Reply #4 on: March 08, 2013, 01:14:57 AM »
if you think that's tough, wait till you have to bash out those emulsion tubes.
  • I'm back
« Reply #5 on: March 08, 2013, 02:48:21 AM »
No, you don't.
« Reply #6 on: March 08, 2013, 04:42:06 AM »
Real carb cleaner soak and a good heat gun to futher soften the crud and patience. Let some of the chems do the work first.
Offline MoMo
« Reply #7 on: March 08, 2013, 04:44:44 AM »
No, you don't.
How else will he be able to get  a straight line to tap the float pin without separating the carb bodies?  Plus, the o-ring on the fuel tees will need to be replaced. All that needs to be done is remove the linkage spring and the 8 screws holding the carbs to the bracket...Larry
Offline lucky
« Reply #8 on: March 08, 2013, 06:50:37 AM »
You may need to take the carbs apart.
That may be the reason the other post was broken. IT depends how badly the pins are stuck.
IF the end of the pin was gripped with needle nose pliers it may the reason it is stuck.
When trying to remove the float pin make sure you have the right tools.
Use a pin punch that has the proper size end. Smaller than the pin too.
Do NOT use a pointed punch because it will spread the soft brass pin end and make it tighter.
Tap from one end with the posts SUPPORTED and then tap from the other direction to make sure it is loose.
Sometimes they will come out easier in one direction that the other direction.
The float pin posts MUST be supported.
A previous owner may have tapped on the end of the pin and spread the end of the soft brass pin making it possible to only get it out in one direction. Look for evidence of
of damage.
PLEASE do not throw the other set of carbs in the trash can.
Many owners may be looking for those carb parts.
Make sure you replace the float needles and if they are metal tipped ,replace the seat too. If they are rubber tipped then replace only the needle.
« Last Edit: March 08, 2013, 06:57:16 AM by lucky »
  • I'm back
« Reply #9 on: March 08, 2013, 07:44:42 AM »
Tap? Tap?!  Well... good luck.
Not, if they're not leaking. Can be tested easily. On my bike they are still good since 1976.
All work not necessary is a lot of work IMO. Read recent posts in this forum where people had lost tiny parts in the proces or had extra parts lying around after reassembling.
Start with the easy work.
« Reply #10 on: March 08, 2013, 10:45:59 AM »
Do you have the broken post? Jim F can weld it back on. Look on the services offered board.
EDIT Just looked, and Jim's thread has disappeared...
« Last Edit: March 08, 2013, 10:48:33 AM by scottly »
Offline goldarrow
« Reply #11 on: March 08, 2013, 11:11:15 AM »
Thanks Scott, I did get in touch with Jim F about welding the broken carb, very reasonable price, but At the moment, I cant afford to pay the FedEx for shipping the carbs back and forth.  Just bought a set of wheels that put another big hole in the wallet.
CB550 K0
Offline bjbuchanan
« Reply #12 on: March 08, 2013, 11:38:05 AM »
Just be careful taking them apart. From your build thread you seem not to be ham fisted, you will be just fine. Carb cleaner and patience
They get broken because you get "mechanics" or just plain retards hitting on a tiny post and then wonder why it breaks
Offline Eddie
« Reply #13 on: March 08, 2013, 04:07:00 PM »
The ones on my goldwing were frozen pretty good. I used acetone, grabbed one end of the pin with needle nose and twist...a little..then more acetone. Little tap and I mean little...with a small punch and drip more acetone...etc.. they all finally came out.  Took me 10 hours to rebuild those carbs.. hope I dont have to take them off again..
Offline BuffaloBill
« Reply #14 on: March 08, 2013, 04:11:06 PM »
Personally I wouldn't consider NOT taking them apart.  It really isn't a big deal.  If your 76 orings aren't leaking yet, chances are they will soon.
Offline bjbuchanan
« Reply #15 on: March 08, 2013, 07:06:33 PM »
Those orings on the fuel tees are pretty damn tough, mine are original. I obviously check it over but they don't leak at all and still have a really snug fit to the carb bodies. Whatever material they used was damn appropriate
Offline Randy
  • Nothing like a banging four under my legs..
    • Mission Detail
« Reply #16 on: March 09, 2013, 07:23:49 AM »
Dude I 'll take the carbs apart..I did my 73 500k and had a blast... And I live in the SVF...
1973 CB500k, 1972 CB750 (New Arrival), 1978 Vespa P200 (New Arrival)
Offline Randy
    • Mission Detail
« Reply #17 on: March 09, 2013, 07:30:29 AM »
here's what a finished with
  • I'm back
« Reply #18 on: March 09, 2013, 07:48:26 AM »
On my model they're doubled on each side of the T-joint. Maybe that's the secret.
Offline Randy
    • Mission Detail
« Reply #19 on: March 09, 2013, 08:18:52 AM »
I found them at our Local Do It Center... or Dormans parts drawers..
Offline goldarrow
« Reply #20 on: March 09, 2013, 11:14:16 PM »
Thanks guys for all responses.  The float pin posts survive!  All floats finally came off.  24 hours of soaking pine-sol/water mix, an hour of tapping the pins left and right, twist and pull.
I can sleep now :)
CB550 K0
