Author Topic: Carb Technical  (Read 1610 times)
Offline Pinhead
  • 1979 CB652-ST
Carb Technical
« on: July 22, 2006, 07:53:38 PM »
This PDF document will teach you pretty much everything you need to know about the workings of a carb. It won't necessarily tell you what to change when changing exhaust, filters, etc. but it tells you how the fuel gets where it needs to go.
It also explains that the 14.7:1 a/f ratio is actually the ratio between the vaporized fuel to air. In other words, if the fuel isn't vaporizing, you've got to pump that much more fuel into the engine to get the correct mixture. That's why you have to choke a cold engine. Once the engine gets to operating temperatures, the fuel more redily vaporises and more of it is burned, so you can effectively lean out the mixture. Anyway, that's another topic.
http://www.cryscom.nb.ca/PDF_Docs/Honda_Technical.pdf
« Last Edit: July 23, 2006, 11:50:28 AM by Pinhead »
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline Jugghead
  • I just THINK I'm a
  • 350cc of pure FUN
Re: Carb Technical
« Reply #1 on: July 22, 2006, 08:29:20 PM »
request URl not found :(
9/72 CB350F...15k miles and rising
Offline Pinhead
  • 1979 CB652-ST
Re: Carb Technical
« Reply #2 on: July 23, 2006, 11:30:25 AM »
Blast! They moved it...
How can I upload this file? It's almost 12mb.
Doug
:D
Offline Weatherman
Re: Carb Technical
« Reply #3 on: July 23, 2006, 11:41:34 AM »
I found and downloaded it from here:
http://www.cryscom.nb.ca/Documents.htm
Offline Pinhead
  • 1979 CB652-ST
Re: Carb Technical
« Reply #4 on: July 23, 2006, 11:50:47 AM »
Thanks Weatherman! Original post edited.
Doug
:D
Offline g8ts
Re: Carb Technical
« Reply #5 on: July 23, 2006, 12:18:02 PM »
Nice link thanks...
"rebuild it rebuild it and rebuild it"
quote from 30 year old Honda owners manual.
Good thing though, its good for another 30 years.
78 550 gone sent to friend in Germany
72 750 brown
73 750 Red
74 750 green
74 750 strange color extended forks
75 750 blue
75 500t sold
75 360 cl orange
77 750ss black
82 900c blue
83 650 CX black
Fence and herding dog to keep them all in.
