Author Topic: 1971 CB500 Engine Crack  (Read 1680 times)
Offline mardimus
« on: April 15, 2013, 10:35:32 PM »
Any thoughts on how to fix the below crack.  The engine is a 1971 CB500 and it is going to be rebuilt.  I did some research but nothing real concrete as to how to fix or should I replace. Thanks for taking the time to look.
Offline pangloss
  • CB500 K2 1975 NZ model
Re: 1971 CB500 Engine Crack
« Reply #1 on: April 15, 2013, 11:25:49 PM »
Well it LOOKs to be Non "Structural" in that it's only into the ignition cavity..
 No sign of oil or crankcase penetration..??
If So it could probably be patched..
« Reply #2 on: April 16, 2013, 12:39:51 AM »
If you have the piece(s) epoxy (JB) or tig weld. If not a used lower half
« Reply #3 on: April 16, 2013, 01:19:10 AM »
the cases are matched/machined pairs,they should kept as pairs only.
Offline faux fiddy
  • bike in a box
« Reply #4 on: April 16, 2013, 02:18:13 AM »
+1 I say, or re machine the bottom to match.
I'd say weld or start with  another off the classifieds. Actually jb can work but clean meticulously and rough it up.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #5 on: April 16, 2013, 07:51:10 AM »
Sorry peeps, lower half in UK means everything below the base gasket!! Of course cases are matched pairs and if you get a complete bottom end there will be no need to sort out shells.
Sorry again for confusion
Offline mardimus
« Reply #6 on: April 16, 2013, 08:36:12 AM »
Thanks to all who posted.  I thought about patching it but it seems it would be tough as the pieces are no where to be found.  The other worry I have is the screw thread for the case cover.  You can see it in the pic.  I looked around for a bottom half but also read that ,yes, a bottom half may not match up as they are machined in pairs.  How would one patch this? Anyone have a link to a write up.  I have a friend who can weld but want to read up on it before I make a decision.  Thanks, again.
Offline Mo
« Reply #7 on: April 16, 2013, 09:45:09 AM »
Could you perhaps make a "cast" out of JB weld and shape it do the fracture?
Offline mardimus
« Reply #8 on: April 16, 2013, 10:58:05 AM »
That is a great idea.  I think I might look into that.
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #9 on: April 16, 2013, 03:12:01 PM »
If you could locate a thrashed bottom case you could cut a piece out of it, shape your case so that it fits and then tig  it in. Pat
Regards
Pat from Australia
