Tony,
Measure your pistons. My Yoshimura catalogue only lists 736 high compression stock bore, 748 cc 2 ring slipper kits, 810, and 826 kits. No 836. The 810 kit seems to be the most popular. It uses 64mm pistons, the 826 has 64.5mm, and if you have 65mm pistons it is in all likelyhood not Yoshimura not that this matters. If you'd like to see the Yoshimura catalogue go to SOHC4.net/gallery and search Yoshimura catalogue. If you have 64mm/810 then go to a Honda dealer and get a set of rings for a 68 to ?? maybe 72 CB350 2 cylinder (not CB360). I run the 810. I sent Hasting rings my piston. They verified this. The old CB350 rings work great. If yours is 64.5 then use 0.5mm over size 350 rings.
Jerry
