Author Topic: Battery draining overnight (ignition issue?)  (Read 1095 times)
Offline coolmaven
« on: May 07, 2013, 03:03:19 PM »
Sorry if this is a silly question but here goes... CB750 K4 - With the engine running, if one turns the ignition key to the off position, should the engine stop running?
Offline Fritz
Re: Battery draining overnight (ignition issue?)
« Reply #1 on: May 07, 2013, 04:03:02 PM »
Simple answer: Yes.
1976 CB550F
Offline coolmaven
« Reply #2 on: May 07, 2013, 04:21:58 PM »
Thanks much. My new battery keeps draining on me overnight. Wondering if this has anything to do with it.
My engine keeps running even with the key pulled out. I did recently install a "combo" regulator rectifier.
« Last Edit: May 07, 2013, 04:25:14 PM by coolmaven »
Offline acollin
« Reply #3 on: May 07, 2013, 05:09:54 PM »
Which way are you turning the key?
I drained my battery once because I turned the key to the parking position and did not realize my tail light was on -- creating a draw on the battery.
Offline coolmaven
« Reply #4 on: May 07, 2013, 05:58:41 PM »
Originally thought that that was the case but I definitely turned it off the right way.
Looks like my issue revolves around the new combo RR. Going to start a new topic on it.
Thanks!
