Author Topic: ARD Magneto  (Read 4955 times)
Offline jonnycakes
ARD Magneto
« on: May 16, 2013, 03:04:43 PM »
I've used the search to no avail.......I need the belt size and pulley sizes for a FM type ARD magneto.  And a suggestion of where to get them.  Somewhere was a list of FM parts......maybe a ARD sticky?
'Matic-Fanatic
Offline BLUE71TURBO
Re: ARD Magneto
« Reply #1 on: May 16, 2013, 03:24:13 PM »
 I myself have the later CDM  A.R.D.  Magneto on my bike.  Terry from Australia or Retro Rocket should be able to help ya. They both have Fairbanks Morse  A.R.D. magneto's.   ;)   If you need magneto parts, here is a place that can help you with parts or rebuilding services......
                                        http://www.magnetoparts.com/index.html
 As for pulley's and special belts this is the place..........
        http://shop.polybelt.com/main.sc
Offline jonnycakes
Re: ARD Magneto
« Reply #2 on: May 16, 2013, 05:02:02 PM »
Cool, how about more specifics on pulley and belt sizes / part # to order?
'Matic-Fanatic
Offline jonnycakes
Re: ARD Magneto
« Reply #3 on: May 16, 2013, 07:20:02 PM »
Alright.....found this for the belt and pulleys......
Browning    Stock #    Price    Desc
 Model
15XLB037    2L518    $11.41    sprocket  15 tooth
30XLB037    2L526    $21.04    sprocket  30 tooth
150XL037    2L565    $4.15    belt  75 tooth
Now for FM parts....
From this.......... http://forums.sohc4.net/index.php?topic=14994.125
'Matic-Fanatic
Offline Ricky_Racer
Re: ARD Magneto
« Reply #4 on: May 16, 2013, 10:07:08 PM »
Johnny, are you certain the ARD takes a 150mm belt? My records indicate a 160mm length (Gates 160XL037 PowerGrip Timing V-Belt). Thanks in advance for clarification. I guess I'd better check it on an ARD tomorrow... RR
« Last Edit: May 16, 2013, 10:19:02 PM by Ricky_Racer »
Offline BLUE71TURBO
Re: ARD Magneto
« Reply #5 on: May 16, 2013, 10:41:14 PM »
 Model
                 These are not the stock spec's for the A.R.D.  Fairbanks Morse magneto.  Puppytrax made up his own setup using different pulley's and belt.   He clearly stated that he wanted to use wider pulley's and belt .   ;)
Offline Ricky_Racer
Re: ARD Magneto
« Reply #6 on: May 16, 2013, 11:07:12 PM »
Okay, cool! Thanks! I was sure hoping my records weren't fouled up. I'd better check anyway now that my paranoia has been piqued.  :-\  RR
Offline Jim F
  • go baby go
Re: ARD Magneto
« Reply #7 on: May 17, 2013, 07:33:27 AM »
I got the pulleys and belts from a company named Bearings and Drives (You can google them)
I had mine rebuilt buy this company
Mainely Magneto
127 Cyr Road
Cross Lake TWP
Maine 04779
1-207-834-7309
Steve and Debbie Belanger
He is very familiar with the ARD Systems
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline jonnycakes
Re: ARD Magneto
« Reply #8 on: May 17, 2013, 02:09:23 PM »
Still hoping for pulley and belt part #s.........
Found some #s on the pulleys
30XLM037X.570
15XL
What length belt do I need?
« Last Edit: May 17, 2013, 02:22:06 PM by Jonnycakes »
'Matic-Fanatic
Offline Ricky_Racer
Re: ARD Magneto
« Reply #9 on: May 17, 2013, 03:42:36 PM »
Johnny, if you're changing pulleys I don't think anyone will know since the only info available on belt length is for use with stock pulleys. After you get your pulleys mounted, you might want to run a string around both pulleys and then measure the length of the string in millimeters. That should equate to the first three digits of the belt number. RR
Offline jonnycakes
Re: ARD Magneto
« Reply #10 on: May 17, 2013, 04:53:21 PM »
Those are the stock polleys
'Matic-Fanatic
Offline jonnycakes
Re: ARD Magneto
« Reply #11 on: May 17, 2013, 05:10:59 PM »
is this the stock belt?
160XL, 16" Outer Circle, 3/8" W
'Matic-Fanatic
Offline Turbogrimace
    • Draft Cycle Works
Re: ARD Magneto
« Reply #12 on: May 22, 2013, 04:47:37 AM »
I have a few belts and pulleys on my shelf.  Jleather here and on the hondachopper board is using them to rebuild his mag.  send him a message and ask him what size the belts are.  He's got all my stuff nwo.
    • Draft Cycle Works
Re: ARD Magneto
« Reply #13 on: May 22, 2013, 04:59:34 AM »
I just checked aht the belt should be 160 mm.  The pulleys are 15 and 30 tooth.  The 30 tooth requires a tapered bore and the 15 needs a stepped 7/16 bore under the pulley and a 3/8" bore through the shoulder where the set screws are.  you can cut the 7/16 bore so that it aligns the pulley correctly with the 30 tooth when it's fully pressed on and mounted.
Offline jonnycakes
Re: ARD Magneto
« Reply #14 on: May 22, 2013, 06:33:16 AM »
Cool, that's what I needed thanks brother
'Matic-Fanatic
Offline Ricky_Racer
Re: ARD Magneto
« Reply #16 on: May 22, 2013, 07:33:57 AM »
Cut the taper first then fit the second pulley..  20 thou more off a taper can move it over a lot..
Offline jonnycakes
Re: ARD Magneto
« Reply #18 on: August 02, 2013, 02:26:22 PM »
After new parts, it looks cool and the 'matic loves the full advance
'Matic-Fanatic
