Author Topic: Picked up a 1970 K0, I think  (Read 4527 times)
Offline adsVA83
« on: May 25, 2013, 07:04:42 PM »
So I don't post a whole lot here, mainly to ask questions when I get in a bind with something I don't know.  I did a complete restoration on a 74 B750, it's almost complete, just waiting on paint on the tank and side covers.  Anyway, I'm familiar with the Sandcast and how rare they are, parts are hard to find etc, but I really don't know that much about the earlier models.
Fast forward to tonight.  I found a CB750 on craigslist that didn't have much information (not even the year, just pictures on the ad) but the price was right, so off I go to check it out.  I get there and the lady tells me it is a 1970.  I ask if she has the title, because the tank is definitely not a 1970 model, it was from the later bikes with the black area painted in the middle of the stripes.  Sure enough, the title says 1970 on it.  By the motor number, I knew  it wasn't original to the bike because the number was WAY higher than the VIN on the neck.
Long story short, I bought it and got it home to check the VIN.  I looked up the VIN and it appears to be a K0 model (CB7501010850).  The motor appears to be from a K5 though being 2396499.  My question is, what were the parts to look for that were specific to the K0 model??  I know it's a hodge podge of parts right now, I just want to be able to tell what is original and what isn't.
Re: Picked up a 1970 K0, I think
« Reply #1 on: May 25, 2013, 07:33:20 PM »
Cable pull carbs, sharp fender ends front fender, smooth airbox, gray caliper, painted. Headlite esrs, louvered sidecovers, ducktail seat, short plastic chainguard., black kill switch, blacktop rear shocks, different front lower legs.. Show us a pic..
Offline adsVA83
« Reply #2 on: May 25, 2013, 07:57:25 PM »
I'll get a picture when the sun comes up in the morning.  Judging by what you said, the frame may be the only thing K0 about the bike.  I don't think it has any of those items you mentioned at all.
Online Stev-o
« Reply #3 on: May 25, 2013, 08:54:09 PM »
Although sand cast technically refers to the engine (manufacturing process) that frame with title may be quite valuable to the right person that possibly has an engine in that number range.
Post some pics
Offline adsVA83
« Reply #4 on: May 26, 2013, 04:40:52 AM »
Swoop
« Reply #5 on: May 26, 2013, 05:09:52 AM »
Looks to me like it may be a restamped number????  Font does not seem right to me. Not too many KO parts on it either.
Steve
« Reply #6 on: May 26, 2013, 06:15:29 AM »
The engine numbers if a 75 does match all the bodywork like the paint color,turn signals etc.
« Reply #7 on: May 26, 2013, 07:39:44 AM »
Looks like someone used a 70 frame with reggie, and put almost a whole. 75 model onto it.
 Question for you, when tying down the bike..why not just use 2 tiedowns , from the handlebars to the boxcorners ?
Online Stev-o
« Reply #8 on: May 26, 2013, 07:41:32 AM »
Looks in pretty good shape.  Try to start it yet?
Offline Tews19
  • I am no
« Reply #9 on: May 26, 2013, 07:57:52 AM »
Nice find!
1970 Honda CB750 survivor.
« Reply #10 on: May 26, 2013, 08:01:01 AM »
Just went out and checked my 74 frame stamp and see it has a slash mark between the CB750 and the numbers like this CB750 - XXXXXXX. The pictured bike does not have the slash,numbers just run altogether. Hmmm. Will have to check my K0 and other earlier bikes down at the shop next time to see if they have that slash or hyphen mark,or one of you guys take a peek. Maybe it is a restamp ??  I take it the metal ID plate on the other side is gone ?
 PS-Nick since your up and at'em go check your 71 frame vin for a slash mark.
« Last Edit: May 26, 2013, 08:04:08 AM by ekpent »
« Reply #11 on: May 26, 2013, 08:33:45 AM »
Check the brake pedal side,see if there is a pedal stop bracket welded to the frame.
 I thought the numbers looked ok..minus the - issue..look at the crater in the weld above it. Typical of the welds on the early frames.
Offline adsVA83
« Reply #12 on: May 26, 2013, 09:02:46 AM »
It doesn't have a metal ID plate on the other side like my '74 has, it has a sticker with that info that looks similar to the ID plate, but not the riveted plate.
As far as only using 2 straps from the corner.  I just bought the truck and the previous owner put a bedliner in it and didn't cut out holes for the anchor points in the corners.  Lets just say I had to try and improvise with tying it down.
The bike does start and run, kick start only at this point.  I need to do some diagnosing the starter problem.
Wouldn't they have to grind down the old stamped numbers on the neck, if they were to try and stamp new ones in their place??  It looks to me like some have said, it's a '70 frame with the rest of the bike looking to be all later parts.
Offline dhall57
« Reply #13 on: May 26, 2013, 09:08:16 AM »
Eric my KO is CB750-103xxxx
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #14 on: May 26, 2013, 09:10:21 AM »
Think that slash in the vin is a major deal. Here are a couple pics scrounged off of E-bay of a couple of K0 frames. Maybe somebody has one without the slash around here ?? Note those sloppy welds on the bottom picture,as Frank mentioned on the early bikes.
« Last Edit: May 26, 2013, 09:14:03 AM by ekpent »
« Reply #15 on: May 26, 2013, 09:12:02 AM »
The 75 brakepedal will have a height adjustment.. And a bracket and bolt welded go the frame to adjust pedal height. Early frames did not have that....can you look..
 If the frame is not factory stamped it could still be a replacement frame, that was then stamped.
« Reply #16 on: May 26, 2013, 09:14:57 AM »
That frame ending in757... Look at the unevenness in those numbers. And the slash mark tilting down.
Offline adsVA83
« Reply #17 on: May 26, 2013, 09:15:17 AM »
All great info.  In the end, I don't want to eventually sell something to someone and mis-represent what it is.  I don't want to sell someone a frame titled as a 70 when it in fact may be a replacement.
« Reply #18 on: May 26, 2013, 09:22:39 AM »
Here is what Frank-754 wants you to check down by the rear brake pedal. The little bracket with the adjuster bolt. Sorry we are so nit picky,just trying to solve a little mystery. The bike overall looks very nice and well cared for.
« Last Edit: May 26, 2013, 09:42:43 AM by ekpent »
Offline Johnie
« Reply #19 on: May 26, 2013, 10:14:15 AM »
Seems that something has been messed with on that number. My KO, K1, K3 & K4 all have the CB750 - XXXXX
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline adsVA83
« Reply #20 on: May 26, 2013, 11:01:56 AM »
It does have the bracket and bolt to adjust the rear brake pedal.
Offline Tews19
  • I am no
« Reply #21 on: May 26, 2013, 11:06:36 AM »
Funky vin stamp is right. But looking at the bike, if you plan to keep I wouldnt worry about it. The tank side covers and gauges all look great. Contact the person you got it from to find out any info you can
Swoop
« Reply #22 on: May 26, 2013, 12:47:19 PM »
Definitely a restamp .....IMHO....look at the 0's....round instead of oblong.....not mentioning the dash mark.
Steve
Offline Johnie
« Reply #23 on: May 26, 2013, 01:49:38 PM »
So what number is on the title? Does it match the frame or engine number?
Oshkosh, WI  USA
Offline adsVA83
« Reply #24 on: May 26, 2013, 03:18:28 PM »
The title matches the frame number and is called out as 1970 on the title.  Something I just thought of.  I recently had a CB750 with a title that matched the number on the motor, it did not match the number on the frame.  I did some research and found out some states on motorcycles back then titled bikes per the motor, not the frame.  Such was the case with some of the old Harley's, they only had numbers on the motor and not the frame so that's how some states continued to title them until year 19xx, not sure the exact year.  Problem is, other states wouldn't register/transfer a title that didn't match the VIN on the frame, so those bikes titled per the motor had issues when trying to transfer to another state.
Is it possible this title was originally married to a motor with this VIN, someone from a state that titled them only by frame numbers bought it and had issues getting it transferred, so they re-stamped the VIN in the neck??
