Author Topic: tapered steering bearings for a 1976 CB550  (Read 1093 times)
Offline Mooshie
« on: June 05, 2013, 06:31:19 PM »
Time to replace my steering bearings.  Anyone have any opinions on the best ones and part number (or better yet a link?)
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline Tews19
  • I am no
Re: tapered steering bearings for a 1976 CB550
« Reply #1 on: June 05, 2013, 06:38:05 PM »
I got my set in the mail a few days ago for my 77 550F.
Got them off ebay. I think 30 something bucks from peak-moto sports
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
1970 Honda CB750 survivor.
Offline Tews19
  • I am no
« Reply #2 on: June 05, 2013, 06:43:58 PM »
Oops all balls is covered up
Offline Mooshie
« Reply #4 on: June 06, 2013, 03:57:16 PM »
Thank you Tews and Paul.  I will get the all balls as you suggested.
1976 CB550F
« Reply #5 on: June 06, 2013, 05:00:58 PM »
+1 All Balls.  Is this something you plan to tackle yourself?
Its actually easier than most noobie mechanics think.
« Reply #6 on: June 06, 2013, 05:25:27 PM »
Late to the ball again.
I got mine from ebay, but amazon has the best price, afaik.
Offline Mooshie
« Reply #7 on: June 06, 2013, 07:15:14 PM »
I do work on the bike but this is something I will let someone else handle.  Though I plan to assist so I can learn... ;)  Any tips you can provide?
1976 CB550F
Offline goldarrow
  • one day, i'll be an
« Reply #8 on: June 06, 2013, 07:36:43 PM »
I learn best when I actually do it myself :)
the spacer for the lower bearing is the thin one (or most likely).
CB550 K0
« Reply #9 on: June 06, 2013, 07:54:43 PM »
Do you have a center stand? Easier if you do and you'll have to support the front end somehow or use a motorcycle jack to raise the front. Take off the tank to reduce the risk of damage and use ropes to hold your handlebars and headlight so you don't have to dissemble everything.
Doing this in a garage with open rafters makes it easy.
And you'll need a long drift punch to remove the old races from the frame. A pipe will work in a pinch.
There are many threads, read up for other tips.
Not real difficult if you know the procedure. And we're here for you....
Offline Tews19
  • I am no
« Reply #10 on: June 06, 2013, 08:02:53 PM »
Definitely try yourself..... I got these down where I can start and have it back together in an hour and 30 min tops.... Stev-o explained it well.... Or you can measure a 2x4 to 31 inches.... Put on center stand...... Put the 2x4 under the neck to support it....
