The SOHC/4 World Tour is in under way.
I'm going to dress the points (sand with emery paper, right?) then check the gap.
Unless you plan to replace your points soon, don't use silica on the point cantacts. Tiny pieces break off and embedd in the soft metal of the points. Silica is insulation and the points burn up faster due to the reduced electrical conract area.
