Author Topic: Tail, dash lights only come on when turn signals are full active  (Read 635 times)
Offline madScientist
The bike is a 78 cb750f
I have my electrics back together and, for the most part, everything works. With the exception of the tail light and the dash lights both remain off. That is until i activate the turn signals. It doesn't matter whether it's full left or full right they only come on then.
I have good continuity all the way to the fuse block for both the brown/white and the brown/blue wires. When i put power directly to the fuse I get active lights. I have no voltage to the brown white, either at the switch or in the bucket until I activate the turn signals. From the diagram it would appear that there are few interspersing connections in between the headlight bucket and the block for this circuit. I would like to refrain from ripping open the loom but I will if I have to.
It looks like the circuit is completed through the turn signal switch body? Could that be bad? What am I missing?
Full disclosure...i put new connections on the harness, tore it apart (unwrapped it) and fixed any exposed wires (mostly green and red), and have a blade type fuse block that I put in. However I made sure when I wired it that the wires went according to the original block. I haven't made any other alterations.
I really want to fix the problem the right way and I'll admit i'm not terribly good with electrics. Any help is appreciated!
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Re: Tail, dash lights only come on when turn signals are full active
« Reply #1 on: May 31, 2013, 05:29:22 AM »
I also jumpered the black and red wires on the main switch to rule that out. Same result. This is something really simple i know it! I'll study the diagram some more but if anyone has any insight i'd appreciate it!
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
« Reply #2 on: May 31, 2013, 05:53:59 AM »
I think i might have figured it out (haven't looked at the bike yet). I've been staring at the color coded diagram and see a black wire (energized 12v at the switch) to power the circuit. I haven't verified whether that's it or not!
I think i'm missing the black wire to energize the circuit. I'll have to look at it this evening or tomorrow.
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
