Author Topic: Simple Tach Cable Question.  (Read 1371 times)
Gibeon
« on: August 08, 2006, 01:12:53 PM »
I bought a 72 CB750 in May and it came without a tach or tach cable.  I have finally purchased a tach cable (bought the tach a couple months prior) and I have no idea if I'm just supposed to jam the cable into the hole and onto the "tach drive shaft", or if there is a part that actually holds the cable onto/into the case.
It's a pretty idiotic question, but there you have it.
You know, I'm not actually certain the tach drive even works, it's "unsealed" (meaning I can see the drive shaft/pin), and the cable will pretty much just slide right in if I push it - it doesn't seem very secure...
TIA!
-Gib
johnny-from-bel
Re: Simple Tach Cable Question.
« Reply #1 on: August 08, 2006, 02:18:31 PM »
The is a screw on the valve cover. Its above the receiver at 90 degrees. Slide the tachcable in and fix it with the crew.
It will work without the seal but will leak oil like hell. Even with the seal my K6 leaks
« Last Edit: August 08, 2006, 03:11:03 PM by johnny-from-bel »
Gibeon
« Reply #2 on: August 08, 2006, 03:14:59 PM »
Thanks!
(Now I wonder if I'm missing the set screw as I don't remember seeing it last night.)  :)
eldar
« Reply #3 on: August 08, 2006, 03:20:19 PM »
I think the screw is an M8 about an 3/4 inch long or so. I am not sure and do not have a shop book at work ;)
Offline dusterdude
« Reply #4 on: August 09, 2006, 09:02:00 AM »
gee eldar,if you dont have anything constructive to add to the question why say anything. ;D ;D :D.daggone k8 guys.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
« Reply #5 on: August 09, 2006, 09:20:08 AM »
Ummm ??? What did you say ??? :D
Offline dusterdude
« Reply #6 on: August 09, 2006, 10:39:10 AM »
i knew you would have a snappy comeback. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
