As Hondaman noted...  if you hook up a timing light, you can see it, and hear it. Seems to actually be 2-3 module. Erratic spark on both 2, and 3. Now it could be the coil, but I don't hear much about Dyna 3 ohm coil problems. It could be the plug wires, but if it was a plug wire the problem would only show with the timing light on that wire, not both wires, as in this case...  I'm betting on the 2-3 module.
Maybe if we round up enough dead/dying module owners, Dyna will have to respond with some kind of relief effort.
Any idea what they do if you are not the original purchaser???
