Author Topic: electrical shutdown on hiway tonight  (Read 1345 times)
Offline my79650
  • old school 750 carbs on a cb650
« on: July 05, 2013, 09:44:54 PM »
79 cb650: out for a drive tonight and the engine was working great at 70 mph i lost all my lights and the engine quit on me. Pulled over and got to neutral; both the oil and neutral lamps were dim, no dash or any other lights would light up on the bike. the park light side of the ignition switch is fine as i had the tail light when i turned the key to that position. i replaced the battery and rotor and the r/r this year as new plus i fixed the wire harnass for the stator. What i was wondering is what can short out to just kill practically everything on the motorcycle? Any ideas or suggestions is appreciated, thanks.
« Last Edit: July 05, 2013, 09:46:27 PM by my79650 »
Offline grumpy
  • ..... '73 750K3 .....
Re: electrical shutdown on hiway tonight
« Reply #1 on: July 05, 2013, 09:48:57 PM »
check the fuses?
Offline 74750k4
« Reply #2 on: July 05, 2013, 09:54:11 PM »
Exactly.
I had that happen to me. The main fuse was blown, and I suspect the brake lamp wire shorted. I was slowing down when it happened. Not sure if that matters though...
Offline bjbuchanan
« Reply #3 on: July 05, 2013, 09:54:36 PM »
Replace your fuses with other ones or check continuity or resistance if you are stubborn like me. Check voltage at the battery after sitting for the night, what does it say? Should be up north of 12.5 for sure otherwise you have some investigating to do of your charging system
Offline painteddigital
    • Portfolio
« Reply #4 on: July 06, 2013, 12:11:07 AM »
I've had this happen once or twice to my 550. Not sure of the wiring differences, but when I wiggled my top wiring harness, the lights came back on. I cleaned it out with some vinegar and a brush and inspected the wires for corrosion. Then put some dielectric grease to help the connection. Seems to have fixed it.
Offline toytuff
  • "watching the pinheads"
« Reply #5 on: July 06, 2013, 02:58:59 AM »
Could be in the ignition switch also. I remember reading a few posts on this.
Just a thought.
tt
Offline my79650
« Reply #6 on: July 06, 2013, 03:01:17 AM »
Thanks for the tips, will post results this afternoon.
Offline my79650
« Reply #7 on: July 06, 2013, 08:10:48 AM »
All the fuses are good, even the homemade main fuse made out of wire. Was like that when i bought the bike. The battery was at 9.45V cause i had to keep turning the rear park lights on and off to keep from getting run over last nite. The r/r tested good, didn't fry it. I went to test the stator and the black wire insulation was melted nearly all the way up the harness....my own fault for not making sure the harness was in the proper route. I don't know what it was except maybe it was grounding out on the frame and stopped everything. when i unplugged the stator i got everything back plus it started up after a few hrs on the trickle charger.
Offline my79650
« Reply #8 on: July 06, 2013, 08:15:55 AM »
Cell phone pics...since i suck a$$ at soldering; i'm going to get my other stator and harness and use it...why did Honda say its ok to use soft steel screws in aluminum? I got the 3 for the stator itself to turn. The 2 for the brushes...just made them round!  Maybe i can drill them out and retap them.
« Last Edit: July 06, 2013, 08:17:32 AM by my79650 »
Offline bjbuchanan
« Reply #9 on: July 06, 2013, 08:48:32 AM »
Drill the heads and vice grip the studs should come loose. Get yourself a handheld impact driver. Anywhere from 9$ (harbor freight/princess auto) to 25 for craftsman. You will feel like a clown for not having gotten one sooner. Small fragile stuff just needs to be supported well and don't use the big hammer on em
Offline my79650
« Reply #10 on: July 06, 2013, 11:41:12 AM »
I got one but it's too big and  for a 1/2" drive. I tried an easy out on the spare unit and that messed it up, then used a few bits to drill it out and damn that's pretty hard steel for a screw. The ones with the fried harness has the good brushes and the screw heads are good. Either i get a smaller handheld or rebuild the harness....fun never ends. Napa is close for me; will call them to see if they have a handheld.
« Last Edit: July 06, 2013, 11:43:01 AM by my79650 »
Offline my79650
« Reply #11 on: July 06, 2013, 06:31:04 PM »
Bought beer, to hell with the new tool! I did the splice job instead. Soldered and the sealed heat schrink. I Did the splice near the engine case where the harness runs before it goes under the side cover for the front sprocket. Was out for a 13km drive@70mph; same as last night and everything worked great. Lights got brighter when i gave it gas. Check the battery volts in the morning.
Offline stickman
  • A vintage 750 is a terrible thing to waste....
« Reply #12 on: July 07, 2013, 06:18:38 AM »
That cold beer does the trick for me too.  I try to start every new task with cold beer and music.  Unless that battery is fairly new, better keep
a close eye on it.  They don't seem  to recover well from trauma.
Stickman
Ed Jones, Lenoir, NC
1971 CB750, 1994 Kaw police bike KZ1000
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #13 on: July 07, 2013, 01:00:12 PM »
And, some of these older bikes will not charge up a battery. The charging systems will just maintain the battery charge. Make sure it has a full 12 volt charge on it, prior to running it.
And then if the battery voltage drops after you have ridden, you will know then you have either a A) Bad Battery or B) more electrical problems
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline my79650
« Reply #14 on: July 08, 2013, 04:57:17 PM »
Battery is a month old; so is the rotor, new r/r box Friday. I ran 100 mile drive Sunday afternoon and i had my multimeter with me. Each time i stopped for break i checked the battery. Shutdown was at 12.40/45v neartly every test. i checked it today after work and it was holding at 12.39v. I am pleased with the results of the repair job.
« Last Edit: July 08, 2013, 05:01:30 PM by my79650 »
bollingball
« Reply #15 on: July 08, 2013, 05:37:48 PM »
All the fuses are good, even the homemade main fuse made out of wire.                                            Now about that fuse? ::)
Ken
Offline bjatwood
  • 1973 CB750-K3
« Reply #16 on: July 08, 2013, 06:01:40 PM »
Glad you got it figured out! Keep the Rubber down  8)
Brian
#24193
