Author Topic: final drive seal slipping  (Read 489 times)
Offline mazingerzeca
« on: July 08, 2013, 06:50:20 AM »
Hello all.
The engine is a CB750 K0. After putting all the bolts to join the crankcases, when I was installing the cylinders and so on, I noticed that the final drive seal had slipped from its hole. I tried to punch it from outside, but I couldn't reach the bottom, so I splitted off the crankcases again. Why did it slip? I put some Threebond 1104 around the seal, expecting that it would seal better, but maybe that was the mistake and I should install it dry. I thought about making sort of a retainer to retain it from the outside of the engine. Anyone had that problem? Thank you.
Re: final drive seal slipping
« Reply #1 on: July 08, 2013, 05:30:36 PM »
This is the seal that slips. The manual says 25x62x7. This one lis 25x62x8, but I don't think that it is the problem, because when properly installed it does enter fully on the crankcase.
Offline kghost
« Reply #2 on: July 08, 2013, 05:54:08 PM »
Hi,
I had that seal back out on one of my K2's.
I siliconed it back in. Judiciously mind you.
No need to goop the hell out of it.
Stranger in a strange land
