Author Topic: float seat  (Read 733 times)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
float seat
« on: July 19, 2013, 09:30:14 AM »
i need a question answer before i re assemble my carbs,my float seat is spring loaded on one end,is the spring loaded end  rest against the float or does the solid end?
Offline lucky
Re: float seat
« Reply #1 on: July 19, 2013, 09:34:15 AM »
That is not the float seat.
That is the float needle.
The float needle rests in the float seat. Just like a valve and valve seat. Same thing.
The pointed end of the float needle goes downwards into the hole of the seat.
It is a pointed cone in a matching hole. See what I mean?
Offline Vinhead1957
Re: float seat
« Reply #2 on: July 19, 2013, 09:35:30 AM »
The tapered end goes in the seat the spring loaded end is the float side
Re: float seat
« Reply #3 on: July 19, 2013, 09:37:06 AM »
...and is called the float valve
the float seat, is what it sits in. ;)
Offline neilc
Re: float seat
« Reply #4 on: July 19, 2013, 09:46:04 AM »
my mistake looking at my manual it says float valve set,anyway thats how i thought it went and is probabaly why setting float height is a #$%*,each spring end probably has a  different resistance even though you angle the carbs when setting the 26mm height
Offline neilc
Re: float seat
« Reply #5 on: July 19, 2013, 09:54:05 AM »
how about stock setting on jet needle,middle i would expect
