Author Topic: need expert advice on removing paint off 1980 cb 650 custom wheels  (Read 1337 times)
gutterman73
i bought a 1980 cb650 custom and want to remove the black paint off of the aluminum wheels without screwing them up. i don't want them to be polished. i just want them to be a brushed aluminum look PLEASE HELP I AM ANOUT TO PUT NEW TIRES ON IT AND IT NEEDS TO BE DONE AT THE SAME TIME!!!!!!!!!!!!!!!! I CALLED A MACHINE SHOP AND HE SAID THAT SAND BLASTING WILL PIT THEM. AND BOILING THEM WILL ALSO
Offline jrrobertsjr
  • If you aren't scared, your not going fast enough.
Re: need expert advice on removing paint off 1980 cb 650 custom wheels
« Reply #1 on: August 08, 2006, 01:51:41 PM »
I would use Aircraft Remover.
This stuff will take skin off so be CAREFUL. Whatever you do, where safety goggles. I cannot express how toxic this stuff is.
I get it at a local autoparts store. (Pepboys if you have one around.)
It is absolutely amazing.
Put it on the wheel with a chemical proof brush. Get it on nice and thick. Let it do the work and take your time.
I removed paint from my tank and brake reservoir. It will take about 5 minutes and you will see the paint curling.
Keep waiting and keep it on thick. I would do 1/4 of a wheel at a time.
Eventually (20-40 minutes), the paint will roll off with your brush.
No pitting. Spray it off like you mean it with a heavy dose of water.
Johnny out.
johnny-from-bel
« Reply #2 on: August 08, 2006, 01:56:46 PM »
Try brake fluid. I have had good results with that.
Offline STLrocker
  • whiskey bent and hell bound
« Reply #3 on: August 08, 2006, 02:44:32 PM »
yes aircraft stripper was the first thing i thought of too. it will burn your skin, so wear gloves and be careful splattering it on your arms. i wa using a few days ago without gloves, and i could feel the burn the rest of the day. stupid.
 i have never had it mess up aluminum, but i would say you dont wanna leave it on there over night or anything. if you use it and get it rinsed off when you're done, you should be ok.
Offline cb650
« Reply #4 on: August 08, 2006, 04:22:27 PM »
I wouldnt think blasting with a less abrasive media wouldnt work.  We use silica and I do aluminumunin all the time.
                         Terry
