Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Hi guys, my set of tools doesn't go past 17mm, I need to buy an extra socket to rotate the crank shaft and set the breaker points. What size is that bolt/washer ?ThanksI tried searching here and in both manuals but it doesn't state the size.
You canalways just measure it.
