Author Topic: Headlight lo/hi switch  (Read 1682 times)
RyanLilly
« on: August 11, 2006, 04:10:54 PM »
I'm going through the rats nest in my headlight bucket and have everything working now except the headlight.
My question is, is the Low/High switch actually a dimmer, or is it just a straight up switch. the switch feels like it goes up in a few increments and I the meter only reads about 9-10volts, but everything else has 12ish.
I have to pull the bars off anyway to bend one of back from when it blew over in those storms a few weeks ago(hurricane in St. Louis, imagine that!) so Ill test all on the components/connectors individually.
BTW, is there some generic switch that will fit, or will i need to order the part if its bad?
Thanks, Ryan
Offline Bob Wessner
  • "Carbs Suck!"
Re: Headlight lo/hi switch
« Reply #1 on: August 11, 2006, 05:03:36 PM »
If I understand you correctly (and I may not) as far as I know, only one filament at a time is lit in the head light, at least on my K0. The switch position determines which one, high or low.
RyanLilly
« Reply #2 on: August 11, 2006, 05:53:22 PM »
That would make sense, I think mine is probably shot because it kind of slides between positions.
Well thanks, I think I'm going to go pull it all apart right now.
-Ryan
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #3 on: August 11, 2006, 06:59:23 PM »
Yes. Power is common at the switch and then selected to either filament. the third connection at the headlight is the ground return common to both filaments.
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
« Reply #4 on: August 12, 2006, 01:32:12 AM »
NOT a good idea to straigten bars as they tend to snap which is rather obviously not a good idea! Replace with new and sort out switch. Housing is similar to other models of same year(s) but wiring may have a "Block" connector instead of individual wires
RyanLilly
« Reply #5 on: August 14, 2006, 12:16:28 PM »
Yeah, I probably will look for a new set of bars, I'll only uses  these long enough to get it on the road.
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #6 on: August 14, 2006, 12:31:42 PM »
what type bars are you in the market for?
i have a brand new, never installed set of chromed drag bars...they're yours for 20 bux if you want them.
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
