Author Topic: New exhaust in the making... FINISHED! Now with better pics...  (Read 14984 times)
Offline jevfro
  • 1975 CB750 K5
Re: New exhaust in the making... FINISHED! Now with better pics...
« Reply #50 on: August 17, 2006, 04:20:37 PM »
The bike really looks sweet!  I want to know if you did the tank.... Is it a stretched stocker?  I might have to make my own exhaust too!  mine is a 4 to 2 but I  really like the 4-4 look.  My exhaust collects in more of a horizontal fashion than the stock 4-4 might look cool though if I put megaphones on all 4 instead of the two cans I've got now.... hrmmm probably wain until winter.  Thanks for the inspiration
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #51 on: August 17, 2006, 06:36:54 PM »
Well Done!!!!
There is nothing better than a one-off CB750.  What's next?
Sparty
1972 CB750 K2 Cafe' Style
Offline DME
« Reply #52 on: August 17, 2006, 10:35:39 PM »
Thanks all for your nice comments  :)
You can find info on the tank and the rest of the bike in this thread:
http://www.sohc4.us/forums/index.php?topic=10569.msg99379#msg99379
and in my gallery:
http://www.sohc4.us/gallery/v/members/personal/Daniel+Melander/
Glad you like it!
Well Done!!!!
Sparty
Will go through some performance mods this winter. Eagerly awaiting info.....  8)
Also, a Grimeca or Fontana double sided, twin leading shoe front brake drum is quite high on my priority list.....
Cheers
Daniel
« Last Edit: August 17, 2006, 10:50:41 PM by DME »
Offline mrbreeze
  • Not your average
« Reply #53 on: August 17, 2006, 10:47:45 PM »
I knew those were stock pipes from the pic you showed with the ends cut of and the baffles hanging off. Will you have to cut them open again to remove or replace those baffles? At that point of the post,I didn't realize you were gonna paint em black.I do like the look very much though and also dig the custom heat shields.Killer work!!!! I might just keep my stockers after all.
MEMBER # 257
Offline DME
« Reply #54 on: August 18, 2006, 06:31:21 AM »
Glad you like 'em!
Yup, will have to cut them open again if/when I want to repack the baffles....
No big deal, shouldn´t take more than an hour.
Will probably not do it anyway, as I have prepared the welded baffles to take ANOTHER baffle inside if needed...
These are the ones...
Offline Hockers Choppers
  • go away winter!!!
« Reply #55 on: September 08, 2006, 05:39:51 PM »
Have you gathered any info on engine mods? I'm also looking to bump my engines performance this winter. Thinking big bore, cam and head porting. From what I've found out so far, head porting is the best bang for the buck. and maybe a cam? I haven't got much feedback.
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
Hop on a Honda
« Reply #56 on: September 08, 2006, 08:40:00 PM »
Now, that is one good looking Honda CB 750.
Consider your self to have won first prize, its a true work of art. I only hope mine comes some where close.
Dave Australia.
Offline DME
« Reply #57 on: September 09, 2006, 03:56:57 AM »
Right now it looks like I´m going for a ported head and camshaft.
Will probably use Megacycles 125-05 or the 125-NR.
The engine is  rebored to 2:nd overdimension and fitted with NOS Honda pistons and I just can´t afford doing it all over again  ;)
Should be enough to smoke that oily Norton that has left me for dead at the stoplights all summer long  >:(
Cheers
Daniel
Offline DME
« Reply #58 on: September 09, 2006, 03:57:57 AM »
Dave Australia.
Thanks a lot!
Cheers
Dan
Offline Rocker
  • The one, the only!
« Reply #59 on: March 21, 2007, 12:54:35 PM »
Man, that is a sweet ride! For those of us interested in turning out750s info cafe racers, what would be some good do's and don't, helpful hints, and other things to look out for. Also, where is a good source to get cafe parts for the 750s? I know Carpy sells some at http://www.cb750cafe.com but was not sure if there are other good resources someone else knows of.
Thanks!
~Rocker (aka Adam) | rocker@sohc4.net | SOHC/4 member #4151 | Facebook
Current Bikes:
1975 CB750 K5 pic
1974 CB360T " lil' twin " Rebuild thread
1976 CB550 K2 Cafe Racer build thread
1975 CB550 K1 parts bike Parted out and cut up.
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline dagersh
    • Photos
« Reply #60 on: March 21, 2007, 01:03:14 PM »
Adam,
Hop into the FAQ section and go nuts!  It will give you great answers to your questions!
Welcome - and remember we love pictures!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Rocker
« Reply #61 on: March 21, 2007, 01:34:04 PM »
Ah, will do.  ;D
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline gpdesign
  • '76 k6 750
« Reply #62 on: March 21, 2007, 02:57:27 PM »
Glad you like 'em!
Do you mind if I ask where you found the louvered muffler baffles? I need a couple/four for my pipes.
Thanks!
'76 750K6
'71 CB450K4
'95 CB1000
'03 KLX400SR
Offline DME
« Reply #63 on: March 22, 2007, 01:57:42 AM »
Glad you like 'em!
Thanks!
Just bought some 1 mm perforated sheetmetal and hammered it into a tube.
Worked like a charm.
Cheers
Dan
Offline HellFishTat
  • I've UPGRADED to a '99 BMW R1100S
« Reply #64 on: May 24, 2007, 01:15:59 PM »
I'd love to hear how, and how much time, went into the tank.  The whole bike is beautiful
Cheers!
and Ride Safe.
