If anyone is still interested in this old thread:
1. Initial thoughts on the bog experienced when going from idle directly to full throttle?
Normal for carbs with no accelerator pump, vacuum operated slides, or fuel injection. Physics. It should take up to one half remaining throttle twist without stumble, even under load in any gear, though.
Stock air filter? Stock exhaust? Stock pilot screw setting?
2. Oil seeping from tach cable attachment?
I haven't changed one on a 750. But, I believe there is a rubber seal there that likely needs renewing.
3. With my very limited information provided, smoke coming from back of cylinder?
Only a very limited explanation.
Might have something to do with the the engine breather tube.
4. Anything else that comes to mind from the video?
Readjust the valves if the engine was at full temp during the video. Or, check for exhaust header leaks.
Tappet inspection covers appear to need new orings, as well
