Author Topic: 71 CB750 Kickstarter Gear Installation  (Read 1381 times)
Offline cakey
  • 5% recipe and 95% process
« on: August 28, 2013, 01:13:30 AM »
Just about finished installing the new parts for the bottom case of my 71 K1.  Took the Kickstarter gear out to clean the case and do an inspection whilst I was changing all the gearbox and case bearings.
I did not pay much attention to the springs when I took it out and now that I have it back in it looks a bit loose.
Can anyone tell by the pics if I have installed the spring correctly. It looks to me like it should be sitting int he groove in the case with tension on it?
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
Offline classic bike tuner
  • http://www.cmrch.nl/
    • cmrch.nl/
Re: 71 CB750 Kickstarter Gear Installation
« Reply #1 on: August 28, 2013, 03:53:54 AM »
middle picture ;  the divice witch is pointing up must be behind a steel part about 180 degree of the position now ; then wan you get it together the spring wil have pressure
olso the schaft hase one position to fit
dont hammer the locking pin compleet in the case
stay kalm  ; be patieence and take your time
gerrit
Offline cakey
« Reply #2 on: August 28, 2013, 03:58:21 AM »
Thanks gerrit.
I think I understand what you mean. I will have another look when it's daylight. Appreciate the feedback
