Author Topic: Can't shift gears  (Read 898 times)
Offline indyjoel
Can't shift gears
« on: September 13, 2013, 03:02:12 AM »
I bought this bike a whole ago and it sat for a while but started and shifted ok.
I tried to start it and shift into neutral but no go.
Drained the glop that the oil had become and put new stuff in but still no good shifting (not that it was that)
I have taken off the gear shaft cover and think the issue is the gear shift side plate that won't move freely. I can't move it so I can put the stopper arm in the slot
Offline Vincent P
Re: Can't shift gears
« Reply #1 on: September 13, 2013, 03:46:35 AM »
How is the clutch in regards to movement, and adjustment?
I would look at this and see if it attributes to the issue your having.
1973 Honda CB750 K3
Offline indyjoel
« Reply #2 on: September 13, 2013, 03:57:14 AM »
That's my next port of call
I am going to pull the cover in the morning to check if the clutch cable is engaging
Fingers crossed
« Reply #3 on: September 13, 2013, 04:07:51 AM »
Not unusual for the 750's to get stuck clutch plates if they have been sitting for a long period. They usually break loose when the engine gets started up and some fresh warm oil gets flowing again. Tying the clutch lever back to handle can help also.  Should still be able to snick the bike in gear though.
Offline lucky
« Reply #4 on: September 13, 2013, 06:36:27 AM »
When you are trying to put it in gear you do know that rolling the bike a few inches forward will help right?
Offline nccb
  • 1974 CB750 Four
« Reply #5 on: September 13, 2013, 06:41:21 AM »
I would try rolling it around and trying to start the engine to warm it up.
Offline indyjoel
« Reply #6 on: September 13, 2013, 09:05:23 PM »
Tried to roll back n forth
The weird thing was I removed the clutch cover and played with the cable and pushed back n forth again (after having changed the goofy oil last week) and she POPPED into neutral
YAYYYYYYY
Thanks for all ideas
Now I only have to deal with the broken gear selector cover I broke, the screws I had to drill out, leaky float bowls, etc etc
Oh forgot front and back brake rebuild, forks etc etc
Butttt I love it
Online scottly
« Reply #7 on: September 13, 2013, 09:19:32 PM »
Are you in Sydney, Australia???
Offline indyjoel
« Reply #8 on: September 14, 2013, 02:43:47 PM »
Sure am
« Reply #9 on: September 15, 2013, 01:28:29 AM »
On all the Hondas i have worked on you have to rotate both shafts to move between gears with engine on the bench so just trying to move the gearshift without the engine running or moving the bike just don't work
