Author Topic: new chain  (Read 1172 times)
Offline tramp
new chain
« on: August 15, 2006, 02:35:44 PM »
i have a 1978 750f that needs a new chain
the parts guy i called said that it took a real oddball size called a 6-30
its kinda pricey so i'd figured that i would find out if he's right
any info will help
1974 750k
Offline Bodi
Re: new chain
« Reply #1 on: August 15, 2006, 03:10:52 PM »
Yes, it has a 630 chain.
You can convert to 530 chain, modern 530 chain is lots stronger than 1970's 630. This makes it a bit lighter, and you'll have more choices in chains. partsnmore has the sprockets, I think JC Whitney may as well. If you like the 630 chain, make sure the sprockets are OK if you replace the chain. Normally I find they are done when the chain is.
eldar
Re: new chain
« Reply #2 on: August 15, 2006, 03:44:42 PM »
the 530 is fine for our bikes. The older 750s had the 530 to start with but chains in those days were too weak. Now a 530 is strong and the 630 is almost unbreakable practically.
Many switch to the 530 as it is lighter and quieter and takes a bit less power to turn. Also more choices in chains and sprockets. and they are cheaper.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: new chain
« Reply #3 on: August 17, 2006, 11:17:57 AM »
Do change the sprockets too.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
