Hi, I have an old 1980 CB650 Custom that Im working on rebuilding the carbs. I bought a set of rebuild kits for the right year and whatnot for them but got the wrong seals. This was off the old bike barn website. After doing some research I found a set of rebuild kits on the parts n more website that appeared to have the right shape seals but they were for the 1977-1978 CB750.
Were these carbs interchanged between the 2 bikes possibly? They are Kei Hin carbs.
Here are some links to the sites and listings:
The Set I bought for the bike, 2nd listing down from the top:
http://www.oldbikebarn.com/motorcycle_parts.php?subcategory=Carb%20Rebuild%20Kits&bike=CB650The set I found on Parts N More: Also the 2nd listing from the top:
https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=carbSo my question is, is the set from parts n more the right set?? as far as I can tell from the pictures, the bowl gasket, top gasket and needle apear to be the same as the ones from the bike but Im not sure about the rest of them. And I do believe they are the right carbs for the bike because I have another bike the same year and model for parts and it had the same carbs.
Any info on this topic would be much appreciated.
Thanks,
Brian
