The SOHC/4 World Tour is in under way.
It looks like it was hooked up to the intergrated cathode retarder unit near the H.E.I.U..(High Energy Ignition Unit)This then enables the retro fitted fusion induction link to be enabled in the CMFEU.If that does not work then turn on the boost fuel.But having diagosed that, its probably a breather from the reduction box.If all else read the instructions!!!LOLDave
