Author Topic: Final drive oil seal replacement  (Read 2228 times)
Offline tlbranth
« on: November 15, 2013, 05:32:31 PM »
Looks like it's going to be a bit of a challenge. I've searched for how-to's and only found a few tid-bits. Soooooooo, if anyone has done this (engine on bike) with enormous success, care to share your method? It looks like removal and install might both prove to be exciting. Any help appreciated.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline tlbranth
Re: Final drive oil seal replacement
« Reply #1 on: November 16, 2013, 09:37:09 AM »
Well OK then. If I come up with any good ideas I'll post them.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Online Johnie
« Reply #2 on: November 16, 2013, 10:57:46 AM »
I think it was andy750 who had a post about doing that. You may want to check with him...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline tlbranth
« Reply #3 on: November 16, 2013, 03:54:50 PM »
Well here's how I did it. I bent a small hook in a stiff piece of wire, stuffed it through the inside of the seal, twisted the hook outward and gave it a tug. I figured I'd need 2 or 3 of them but one did it.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline tlbranth
« Reply #4 on: November 16, 2013, 03:56:13 PM »
Here's the pull
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Vinhead1957
« Reply #5 on: November 16, 2013, 05:20:56 PM »
Can you feel any side wards play in the shaft? A seal may symptom of bearing play.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: November 16, 2013, 05:40:07 PM »
Hey Terry, how did it go? I usually drill a couple of 2" drywall screws one 180 degrees from the other and then pry it out.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #7 on: November 16, 2013, 06:27:09 PM »
Nice method. I'll be doing this soon. This looks like a nice alternative to inserting a screw to pull the seal. Thanks for posting.
Offline tlbranth
« Reply #8 on: November 17, 2013, 09:12:12 AM »
No side play. The seal was 43 years old so it deserved a rest.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline tlbranth
« Reply #9 on: November 17, 2013, 09:17:24 AM »
Here's how I put in the new seal. I used a large socket and pried it in against the case using a herking steel bar. It worked OK but I muffed the seal placement on the shaft. The seal lips were bent outwards. I pushed them back in with a small screwdriver but I'm betting the spring came off. Can't risk it so I'm going to buy a couple more and redo. For the next install, I think I'm going to make a tool. I have an idea for one and I'll post if it works. Meanwhile, here's how I did this one:
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline tlbranth
« Reply #10 on: November 17, 2013, 05:32:15 PM »
Well I ordered a new seal and meanwhile built this installation tool. Don't know how well it'll work but it should.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline tlbranth
« Reply #11 on: November 17, 2013, 05:33:39 PM »
Here's how it looks in (fake) use
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #12 on: November 17, 2013, 09:41:29 PM »
Nice work, Terry.  Is the 'Herken' tool patented, yet?  ;D
Glad I was able to do thos seal with split cases....whatta chore.  :o
