Ah... ok... so your engine has both the inner and outer grooved bearings?
Yeah, I would also like to know what "problem" Honda was solving for with that bulletin.
If I had to guess - and do like guessing (even if I really don't know what I'm talking about)
I would theorize it was to allow the whole assembly to twist a little bit without "cocking" the bearing. Maybe Honda was worried about the outer bearing race being twisted in relation to the inner bearing when everything flexed under heavy acceleration?
I've attached a picture of my engine (75 CB750F) with the newer double row design (so, not like yours), with neither bearing having a groove. It appears to be held in place between the larger outer bearing set-ring and a lip on the case where the inner bearing sits.
I believe your case looks like the left image in the bulletin, correct?
You can buy the bearings without the grooves from any good bearing distributor, but getting them with the correct grooves is more challenging.
Looks like cmsnl has the outer grooved bearing available (assuming they don't send you the superseded part number)
http://www.cmsnl.com/honda-cb750k0-four-usa_model14346/91004438003-bearing-6305hs_91003259000/#.UrOevPRDsucInteresting how this is a HS bearing (or an extra clearance bearing, C3).
Looking at the cmsnl parts list for your bike:
http://www.cmsnl.com/honda-cb750k0-four-usa_model14346/partslist/E21.htmlIt looks like they have two separate bearings options:
"up to serial number: 1048345" or "from serial number: 1048346"
And the former one appears to be the same bearing as the 6205 grooved bearing in the transmission.
Ordering them from cmsnl is probably cheaper than buying the non-grooved bearings and having someone put a groove in it (I had it done and it wasn't cheap):
http://forums.sohc4.net/index.php?topic=60026.msg1313396#msg1313396But... to your point/question, you're looking to put the new "improved" bearings in and I'm not sure if the ones cmsnl are the "improved" ones.
It looks like the service bulletin is just replacing the outer 6305 bearing. I wonder if it's replacing it with a non-grooved bearing and just relying on that full "snap" retaining ring to hold it in place.
Does your assembly have both the full retaining ring (like the one in my picture) as well as the bearing half ring?
