Author Topic: 72 CB500 Clutch Not Releasing When Cold  (Read 393 times)
Offline jmelche2
  • 1974 CB750K
« on: November 26, 2013, 02:42:42 AM »
I recently replaced the cable, frictions and clutch springs with OE Honda parts.  The lift mechanism and rod have been checked and are good.  The issue I have is when I engage the transmission into first gear the bike will stall, similar to what would happen if you didn't disengage the clutch.  The clutch pull fees ok.  I did not have this problem before I replaced the clutch.  Using Honda 10W40 oil.  Only happens on initial start.
« Last Edit: November 26, 2013, 02:44:13 AM by jmelche2 »
Offline jmelche2
  • 1974 CB750K
Re: 72 CB500 Clutch Not Releasing When Cold
« Reply #1 on: November 27, 2013, 02:34:46 AM »
Anybody had this problem?
