Author Topic: Two hole rear hub on CB750K1  (Read 1654 times)
Offline KayOne
« on: November 28, 2013, 03:44:36 PM »
I am in the midst of restoring my CB750 K1 (4/71, 1089xxx) and discovered it has a two hole rear hub. The hub has a 13 followed by a 6 stamped on an internal face if that means anything.
My question is this; reading comments made on these forums, two hole hubs came on KO bikes.  Is it possible that my K1 came from the factory with this hub? The only changes to the bike I have identified is a post '71 drive hub with studs rather than bolts and a Harley 16' rim.
I can trade/barter with a local that needs a two hole hub. He claims the K1's only came with 4 hole hubs. If this is true I can most likely obtain the correct K1 hub and drive hub. Is there anything to identify a K1 hub, other than 4 holes?
If I go ahead and do this, assuming it is not correct, should I be looking for extra$ on the exchange?
Thanks in advance for any information.
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
Offline Tews19
  • I am no
Re: Two hole rear hub on CB750K1
« Reply #1 on: November 28, 2013, 03:59:44 PM »
2 hole is K0/Sandcast from what I have read..... Check out eBay.. Those 2 holes for nice money.. I think the cheapest one I saw listed was over 300....... Maybe it was like that when it left the factory... I would leave it..
1970 Honda CB750 survivor.
Offline kmb69
« Reply #2 on: November 28, 2013, 04:20:46 PM »
You frequently find 2 hole hubs in 16" wheels on eBay. Real popular mod back in the day. The PO probably bought it for that 16" wheel.
The most valuable item you probably don't have is the "rounded" 18" rim that came on that hub. Many of them thrown away when changed to 16".
Not sure what the specific identifier would be for a 4 hole K1 hub. Pretty sure all K1 - K6 are a direct interchange.
True but listing and selling are 2 different things. There are quite a few on eBay now even with the 18" rim that have been relisted several times.
To make Mark happy, "Probably" Did not come from the factory like that.
« Last Edit: November 28, 2013, 07:02:51 PM by kmb69 »
« Reply #3 on: November 28, 2013, 04:44:46 PM »
In the build era of the 750/50/550, Honda frequently recycled parts in their processes.
It went something like this:
4/1971: a 750 engine (or cases) failed QC, needed some work on #2 crank support, like maybe the bearing hole was not bored just right during the align-bore step.
6/71: The engine was recycled through the Engine Department for correction of the 'bad' part (or machine steps) and someone judged the best way to fix it, then it was fixed.
7/71: The engine (cases) put back into the Production Process, and scheduled into another bike build.
The above actually happened to my own 750K2 engine: it started out as a K1 engine, ended up in my early K2. Along the way, the engine serial number was ground out and welded in, then restamped, so I am supposing it got further than just cases only before some defect was identified. (I first noticed this in 1980 when I stripped the paint from the cases, before repainting them - which filled in the tiny edge-of-welds marks in the serial number 'window'). Inside the engine, the #2 crank main bearing support has 3 stamped-in QC marks, and it has a bearing shell one size larger than the others. Since the engines were bored left-to-right, this would seem impossible except for some sort of rework step.
During the years when I actively 'tracked' such things, I came across 2 other 'early' K2 bikes with serial numbers close to mine (...#4530). One was earlier (I think it was ...#4520-something), and had a K1 engine also, the other over 150 numbers later, and had the K2 engine. Many other examples of this sort of 'exchange' of parts abound on these bikes. Even during the K5/K6/F0 era, the engines swapped heads and cylinders, and cams and pistons, a lot. It's not real unusual to find, say, a K6 with pop-up F0 pistons and a K5-era cam: these are real hotrods that develop somewhere around 10.6:1 compression, and the carbs will have #110 mainjets inside. Every now and again you will hear of these 'legendary' K6 bikes. ;)
Offline Dream750
« Reply #4 on: November 28, 2013, 07:43:57 PM »
This may provide another clue, but it’s not the final word. :-\
My spare 2 hole hub has PN: 42601-300-020 and the 4 hole hub uses PN: 42601-300-030.
The 12/71 parts book shows a hub part number change at frame number: 1073286
Offline kmb69
« Reply #5 on: November 28, 2013, 08:28:25 PM »
Good info Dream750 and you are correct - it is not the final word. I think K1's start at Frame 1044650. That would indicate "approximately" 28,636 K1's had 2 hole hubs or "approximately" 73,286 total 2 holes or less hubs were produced. Some very early SC's have NO holes. 1089xxx "should" have been a 4 hole hub. I have a couple of early K1's under 1073286. Gotta have a look now.
« Last Edit: November 28, 2013, 08:30:15 PM by kmb69 »
« Reply #6 on: November 28, 2013, 10:28:43 PM »
I should add this.. I have seen about 4 different styles of backing plates for rear brake..if you look real close at them..
« Reply #7 on: November 30, 2013, 11:05:19 PM »
Roger that! And 2 different brake cams.
